Finding Applied force given Mass and Kinetic and Static coefficients.
To determine the applied force needed to move a refrigerator with a mass of 180 kg, the static friction coefficient of 0.21 is crucial, as it dictates the force required to initiate movement. The normal force is calculated to be 1764 N, leading to a maximum static friction force of 370.44 N. Before the refrigerator moves, only static friction applies, meaning the applied force must equal this static friction force to start movement. Once the refrigerator begins to move, kinetic friction, with a coefficient of 0.13, will take over, resulting in a lower friction force of 229.32 N. Therefore, an applied force of at least 370.44 N is necessary to overcome static friction and initiate movement.
Hieroglyphics
Your family just had anew refrigerator delivered. The delivery man has left and you realize that the refrigerator is not quite in the right position, so you plan to move it several centimeters. If the refrigerator has a mass of 180 kg, the coefficient of kinetic friction between the bottom of the refrigerator of the floor is 0.13, and the static coefficient of friction between these same surfaces is 0.21, how hard do you have to push horizontally to get the refrigerator to start moving?
The one's I'm thinking of are:
Fnet = ma
Fnµ = Ff
So I found the Normal Force and Force of Gravity are 1764 obviously
Force of kinetic friction is 229.32, force of static friction is 370.44
and I think I can do 370.44-229.32 = Fnetx so that Fnetx = 141.12
so then I would know ma = 141.12 so a = .784.
But I'm stuck after that :(
Fnet = ma
Fnµ = Ff
You cannot have static friction and kinetic friction acting at the same time. Static friction acts only when the object is not moving with respect to the surface it is in contact with, and kinetic friction acts only when the object is moving with respect to the surface it is in contact with. Just before the refrigerator starts moving, which type friction force applies? Is there any acceleration of the refrigerator before it starts to move? What force must be applied at the instant just before it starts to move?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
