Finding atomic diameter from molecular diffusion proportionality
ProPatto16
Find the diameter of one atom of argon given that Dp = 2 where D is diffusion and p is pressure.
molar mass of argon is 40g/mol
using that for one atom can find mass in kgs.
but that's its!
im not given V, T or p. can put V in terms of d so that gives me one. need 2 so i can solve for the last one.
the relevant equation seems to be
$$Dp=\frac{1}{\pi d^3\sqrt{m}}(\frac{2kT}{\pi})^\frac{3}{2}$$
good luck finding d.
The diffusion constant has units m^2/s, pressure has units N/m^2 = kg /(m s^2). The product of both cannot be a dimensionless number ("2").
I think there is something missing here.
Unrelated: if you just need T, room temperature is a good value.
It's not a constant. Diffusion D and pressure p are inversely proportional. The info I'm given is as pressure increases the product of diffusion and pressure is 2. So the 2 is the x in D=x/p hence dimensionless. I'm fairly sure that this means T is constant.
Sorry probably a poor worded question.
Given a figure of a graph of Dp vs p for argon and it's a line parallel to x-axis with the value 2.
Question says find diameter of argon. So I don't have particular values for p and D either...
Hmm but I see what you mean... It still needs units... But even then with units it won't make a difference.
And I think there's something missing too.
And I actually have the answer as d=3.1*10^-10m out of the book but that corresponds to a T of about 330K
but there's no way to find T with the info given..
Is that the full, exact problem statement?
If yes, I think you really have to assume that it happens at room temperature, and I still doubt that the units match.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
