Finding Coefficient of Friction
The problem involves calculating the coefficient of friction for a girl ice skating who comes to a stop from 10 m/s over a distance of 100 m. The acceleration was determined to be -1/2 m/s² using the kinematic equation. The gravitational force was incorporated into the friction formula, leading to the conclusion that the coefficient of friction (μ) is approximately 0.051. The discussion clarified that the masses cancel out in the calculations, simplifying the process. Overall, the calculations and reasoning presented were validated by participants in the discussion.
tod88
Finding Coefficient of Friction [solved]
A girl is ice skating at 10 m/s. She stops skating and glides to a stop in 100m. Find the coefficient of friction of the ice.
uk = Fk / Fn
F=ma
I found the acceleration to be -1/2 m/s^2 since
Vf^2 = Vi^2 + 2a * displacement
so
-100 / 200 = a.
Since it didn't give me her weight I don't know how to find gravitational force on her. If the surface were frictionless her acceleration would be zero.
Since her acceleration isn't zero and it takes her 20 seconds to come to a stop, I know that there must be a uk and that it also must be very small. Without her weight, however, I'm lost. Can someone point me in the right direction?
you know the gravitational acceleration.
Ff=(mu)Fn
Fn=Fg
An=Ag
take out the masses, since they are constant
Substitute the formulas for Fk and Fn into the formula for \mu
Ff=(mu)Fn
Fn=Fg
An=Ag
Okay, so
Ff=(mu)9.81 m/s^2
and the acceleration of the skater is -1/2 m/s^2.
I'm not sure what the An = Ag means. Normal acceleration equals acceleration due to gravity?
Does this mean that if force is mass * acceleration and the masses are the same I can just do Ff=(mu)*Fn (letting the mass be 1)
(1)(-1/2 m/s^2) = (mu)(1)(9.81 m/s^2)
SO then (mu) = 0.051?
As I said, write out the full formula. You will see that the masses cancel, leaving just the accelerations.
Your calculations appear to be correct to me.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
