Finding electric field via potential
The discussion revolves around calculating the electric potential and electric field due to a non-uniformly charged plastic rod with charge density λ=cx. The user has derived the expression for electric potential but is struggling to correctly compute the electric field from it. They provided two potential values for the electric field, -3.47 x 10^3 N/C and -1.45 x 10^4 N/C, and are seeking confirmation on their correctness. The user is confused about the implementation of the equations and the relationship between the potential and electric field. Clarification on the calculations and the correct value for the electric field is requested.
DannyPhysika
The plastic rod of the length L=1 m has a non-uniform charge density λ=cx
where positive constant c =2x10^-6 [some unit]. What unit c has to have? Find the electric
potential at the point on the x-axis 1 m to the left from the left end of the rod. Find the
electric field at that point via potential. What is the direction of the field
V = k integral(0 to L) dq/r
E = -dV/dx
Found everything except electric field. I've tried and gotten so confused as to how to implement it. I got this so far:
dV = kλdx/(d+x)
dV/dx = kλ/(d+x)
E = -k(c)(1m)/(2m) = -8.99 x 10^3 N/C
I know it's wrong but I'm so lost as to where to fix it. Thanks
I would like to know if either:
-3.47 x 10^3 N/C
or
-1.45 x 10^4 N/C
Are correct. Thank you :)
