Finding Friction Force on a Break Pad
To find the friction force applied by the brake pad on the shaft of a turntable, one must consider the turntable's mass, diameter, and rotational speed. The problem involves calculating the deceleration caused by the brake pad over a 15-second period to determine the required friction force. Participants emphasize the importance of following forum guidelines by avoiding homework questions in inappropriate sections and providing prior work for clarity. Proper problem-solving techniques and physics principles are essential for arriving at the correct solution. Engaging in discussions about methodology can enhance understanding of the concepts involved.
lostHope
A 30-cm-diameter, 1.6 kg solid turntable rotates on a 1.4-cm-diameter, 450 g shaft at a constant 33 rpm. When you hit the stop switch, a brake pad presses against the shaft and brings the turntable to a halt in 15 seconds.
How much friction force does the brake pad apply to the shaft?
I am struggling with answering this problem and I am not too sure how to approach it.
Hi
This is a homework problem so please post it in the appropriate place. See the top of the Forum Page: "NO HOMEWORK Etc. Etc."
There is a standard way to present your question which involves showing what you have done so far.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
