Finding Initial Velocity to Equations
To find the initial velocity of an object, the appropriate equations depend on the known variables. Key equations include V = Vi + at, s = ut + 0.5at^2, and v^2 = u^2 + 2as. There is no single equation for calculating initial velocity; instead, it requires working backward from final conditions if needed. The choice of equation is contingent upon the information available. Understanding the context of the problem is essential for determining the correct approach.
navarro714
What equation do I use to find the initial velocity of an object?
You can use Velocity = Initial Velocity + Acceleration*Time
V=Vi + at
Or s = ut + 0.5at^2
or v^2 = u^2 + 2as
it depends on what you know already.
There is no equation "to find the initial velocity of an object".
Sorry -- that was a bit hasty. I guess there could be a problem that gave you final conditions and asked you to work backward to the initial conditions. As tyco05 said the equations you would use to do that would depend on what you already know so there is no equation in general "to find the initial velocity of an object".
tyco05 said:
or v^2 = u^2 + 2as
Thank you!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
