How to Write Mathematical Equations on Physics Forums
To calculate the kinetic energy of a rocket with a velocity of 10 meters per second and a mass of 10 kg, the formula Ek = (1/2) mv² is used. The correct calculation yields 500 joules, confirming option b as the right answer. There was some confusion regarding the proper notation for joules, which should be represented as "J" instead of "j." Additionally, users expressed difficulty in formatting equations on the forum, prompting a reference to the Physics Forums FAQ for guidance. Clear communication and correct units are essential for accurate mathematical representation in discussions.
csurfus1
If the velocity of a rocket is 10 meters per second and its mass is 10 kg, its kinetic energy is:
a. 5000 joules
b. 500 joules
c. 10000 joules
d. 1000 joules
2. Homework Equations [/b)
Ek= (1/2) mv2
e=(.5)10x10(2)
E=5000 j
csurfus1 said:
Ek= (1/2) mv2
Good. I assume you mean: Ek= (1/2) mv2
e=(.5)10x10(2)
E=5000 j
Check your arithmetic.
Likes 1 person
Thank you, I appreciate that. I am having a hard time figuring out how to put in the right formulas for this site.
But doing it again, I got 500 j. That right?
Yep! :thumbs:
Except that the unit symbol must be J - not j.
There is an entry in the PF FAQ thread (in the Feedback forum) that describes how to write the mathematical equations here:
https://www.physicsforums.com/showthread.php?t=617567
:smile:
Likes 1 person
