Finding magnetic field component
To find the y component of the magnetic field affecting an electron with a given velocity and acceleration in electric and magnetic fields, the Lorentz force law can be applied. The acceleration in the z direction indicates that both the electric field and the y component of the magnetic field contribute to this force. The electric field, directed in the positive z direction, has a known magnitude, while the magnetic field's influence must be derived from the relationship between velocity and acceleration. The x component of the magnetic field does not contribute to z acceleration, highlighting the importance of the y component in this scenario. Understanding these relationships is crucial for solving the problem effectively.
wendo
An electron has a velocity of 1.63×104 m/s (in the positive x direction) and an acceleration of 1.98×1012 m/s2 (in the positive z direction) in uniform electric and magnetic fields. If the electric field has a magnitude of 19.8 N/C (in the positive z direction), what is the y component of the magnetic field in the region?
this I'm really not sure... but could lorentz force law be applied to this question?
F=q(E+vxB)
C^2= a^2+b^2?
I'm really sorry but I seem to really have no idea bout this one... here's what I thought but is wrong..
Since they give you the acceleration in the z direction, with it the force due to the movement of the electron can be found. (or does this not work because F=ma doesn't apply to electric forces?)
-then I thought maybe if I found the force then i can use Lorentz' equation to solve for B?
But because the question is asking for a y component I'm really stuck on how to relate the acceleration, velocity and E field into finding the magnetic field.
Can someone help push me towards the right direction for this question?? Thanks!
Yes, lorentz force law. And F=ma applies to all forces. If you think about F=q*vxB you will realize that with v is the x direction that an x component of the magnetic field will contribute no acceleration and a z component will contribute only to the y acceleration. So the only two things contributing to z acceleration are y component of the magnetic field and the E field. Does that help?
