Finding mass given force and acceleration
To find the mass of a woman in a lift accelerating at 2 m/s² with a force of 945 N acting on her, the gravitational force must be considered alongside the upward force. The equation F = ma can be adjusted to account for both forces, leading to the equation 945 - mg - ma = 0. By substituting the acceleration due to gravity (9.81 m/s²) and the lift's acceleration (2 m/s²), the mass can be calculated as m = 945 / (9.81 + 2), resulting in a mass of 80 kg. This approach highlights the importance of formulating the problem mathematically to simplify the solution process. Understanding the interplay of forces is crucial in solving such problems.
MMCS
a lift ascends with a uniform acceleration of 2m/s^2 whilst transporting a woman. Calculate her mass if the force exerted on her from the floor was 945N.
ANS: 80KG
I have tried F = MA
M = F/A = 945/2 = 472.5
Inertia may have been taken into account but is this possible without being given the mass?
I hate elevator questions; very tricky!
You have the upward force of 945 N on the lady.
But you forgot gravity also has a grip on her.
Include that, and you will get the 80 kg!
I hate them too! how do i include gravity in there? It would usually be the product of her mass and 9.81 but I am not given her mass
Write it as mg. You'll have two m's in your F = ma equation but it is not a big problem to collect them as like terms in a linear equation. This is an important idea: write it out even if it strikes you as unsolvable - once it appears in front of you in a mathematical form, a whole different thought process in your mind takes over and often the difficulties disappear.
945 - mg - ma = 0
g + a x m = 945
9.81 + 2 x m = 945
m = 945/11.81 = 80kg
Thanks!
