Finding Mass of Object without Scale
  • Thread starter Thread starter SirSpanky0
    Mass Scale
To find the mass of an aluminum rod without a scale, one can calculate its volume using its dimensions and then apply the density of aluminum. The discussion highlights that the rod's shape, likely a circular cylinder, is crucial for volume calculation. Some participants suggest alternative methods, such as applying a constant force and measuring acceleration, though this may still require a scale for force measurement. The conversation also touches on using Coulomb's law or Hooke's Law for different acceleration methods. Ultimately, understanding the rod's dimensions and density is key to determining its mass.
SirSpanky0
I need to find the mass of an aluminum rod without the use of a scale. I have all the dimensions of the rod but I just don't know the right equations etc. Thanks for the help!
This sounds like it might be a homework problem. Perhaps you know the volume of the rod, and its density?
Maybe you're stuck finding the volume of a "rod". A "rod" could have a lot of shapes, though the first one that springs to mind is that of a circular cylinder.
I think that if this is a homework problem you'd do better if you made some effort to solve it yourself, first (the "show your work" rule) - also, there is a special forum for homework problems.
You can accelerate it with a constant force and then divide the force exerted and the acceleration and that will give you the mass. Easy to say, hard to do for a lab experiment in school.
Pete
Pete
Yes, but how are you going to calculate the force with which you accelerate? you may still need a scale.
It depends on the particular way you choose to accelerate it. If you use two charges then you use Coulombs law. If you use a spring then you use the law for springs (the name evades me at the moment).
Pete
pmb_phy said:
[...]If you use a spring then you use the law for springs (the name evades me at the moment).
Would this be Hooke's Law (F = kx)? Sorry if I'm wrong, I just like to think I know what's going on once in a while :-p
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
