Finding mass with forcce and speed
  • Thread starter Thread starter Obsydian
    Mass Speed
To find the mass of the Enterprise, the discussion focuses on using the given forces from the pods, which are 2500 kdyn each, and the two speeds (0.62 km/s and 12 km/s) over an 11-second interval. The acceleration can be calculated using the formula a = (Vf - Vi) / t, leading to the determination of mass through the equation F = MA. The user expresses initial confusion about the process but ultimately finds clarity in applying the formulas. The discussion highlights the importance of understanding the relationships between force, mass, and acceleration in physics. A step-by-step approach is essential for solving such problems effectively.
Obsydian
I need to find the mass of the enterprise.
I have the given...
2 pods (pulling the enterprise) : F=2500kdyn each.
t1 : v1 = 0.62km/s
t2: v2 = 12km/s
Time between those statements : (delta)t=11s
v=m/s
...I don't know which equation to use, everything I have found to find mass or acceleration needs each other figured out first, which is impossible.
Force at 50Newtons.
I am math/physics dumb and haven't taken this stuff in years. I need a place that will show me a walkthrough because I don't know WHERE TO START.
I'm pretty dumb at physics too but here is the way I look at it. You are given two speeds, and a time, which then you can use the acceleration formula. a = (Vf-Vi)/(t). Now you are given a force and found acceleration, F=MA. Solve for mass.
All figured out, thank you!
