Finding moment of inertia for a hemisphere
To find the moment of inertia of a hollow hemisphere about the x-axis, one can start by considering the moment of inertia of a complete spherical shell, which is uniform in all directions. The moment of inertia for the entire sphere can be divided by two to obtain the moment of inertia for the hemisphere, as each half has the same moment of inertia about the axis. This means that the moment of inertia of the hollow hemisphere is half that of the complete sphere. The discussion emphasizes the simplicity of the problem, highlighting that sometimes solutions are more straightforward than they initially appear. Understanding these relationships is key to solving similar physics problems effectively.
dinospamoni
A thin walled hollow sphere of radius 16 cm is sliced in half. What is the moment of inertia of this hollow hemisphere about the x-axis if the areal density is 90 g/cm2?
No idea
I've had no luck with this. I've already found the outward facing area of the sphere and the z component of the center of mass, if that help.
Really anything that could set me on the right track would be awesome
Would it help to think about what the answer would be for a complete spherical shell?
For a complete spherical shell, it would be the same in all directions.
So for half a shell, would it be half of what it would if it were a whole sphere? I feel like that's too easy
Now and then, a problem is much easier than it seems. Each half would have the same MI about this axis, and the MI of the whole sphere would be the sum of the two.
Does this mean MI_z=2*MI_x?
No, it would be the same. Whether you cut the sphere in half along the axis of rotation or perpendicular to it, you produce two halves with the same MI about the axis, so each half must have half the MI of the whole sphere.
Ah I see now. Thanks a ton!
