Finding Principal Root of \sqrt[3]{8i}: Stuck at Arctan?
  • Thread starter Thread starter MikeH
    Root Stuck
The principal root of \(\sqrt[3]{8i}\) is determined by converting the complex number into polar coordinates. The modulus \(r\) is calculated as 8, while the angle \(\theta\) is found to be \(\frac{\pi}{2}\) radians, corresponding to the point (0, 8) on the complex plane. The formula \(\theta = \arctan\frac{y}{x}\) is applicable, but in this case, it leads to an undefined result since \(x = 0\). The correct approach is to recognize the angle directly as \(\frac{\pi}{2}\).
  • Understanding of complex numbers and their representation in the complex plane
  • Knowledge of polar coordinates and how to convert between Cartesian and polar forms
  • Familiarity with trigonometric functions, specifically arctangent
  • Basic grasp of cube roots and their properties in complex analysis
  • Study the conversion of complex numbers to polar coordinates in depth
  • Learn about the properties of cube roots of complex numbers
  • Explore trigonometric identities and their applications in complex analysis
  • Investigate the implications of undefined values in trigonometric functions
Mathematicians, students studying complex analysis, and anyone interested in understanding the properties of complex numbers and their roots.
MikeH
I have to find the principal root of [tex]\sqrt[3]{8 i}[/tex]
But I get stuck at this part
change this to polar coordinates...
[tex]r= \sqrt {x^2 + y^2}[/tex]
which makes [tex]r=8[/tex]
but when I try to find [tex]\theta[/tex]
[tex]\theta = \arctan \frac{y}{x}[/tex]
from the original x = 0 so how do I find [tex]\theta[/tex]?
Don't just use formulas without thinking! When you say change "this" to polar coordinates you mean 8i: in the complex plane, that's the point (0, 8)- on the positive imaginary (y) axis which makes a right angle with the real (x) axis- [itex]\theta[/itex] is [itex]\frac{\pi}{2}[/itex] or 90 degrees.
(Of course, [itex]\theta= arctan\frac{y}{x}[/itex] does work even in this case: [itex]tan(\frac{\pi}{2})[/itex] is undefined.}
Thanks for your help, I found the answer :smile:
  • · Replies 38 ·
  • · Replies 16 ·
  • · Replies 17 ·
