Finding spring compression using PE
To find the maximum compression of the spring when a block of mass 2.0 kg is dropped from a height of 55 cm onto it, the conservation of energy principle is applied. The potential energy of the block at the height is converted into kinetic energy just before it hits the spring and then into elastic potential energy in the spring. The equation used is mgh = 1/2 kx², where m is mass, g is gravitational acceleration, h is height, k is the spring constant, and x is the compression distance. By substituting the values into the equation, the maximum distance the spring is compressed can be calculated. This approach effectively demonstrates the energy transformation involved in the process.
emilykorth
How do you do this? A block of mass m = 2.0 kg is dropped from height h = 55 cm onto a spring of spring constant k = 1960 N/m . Find the maximum distance the spring is compressed.
m
the conservation law of energy:
the kinetic energy of the block=the potential energy at the beginning=1/2kx(square) with x the distance the spring is compressed
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
