Finding Spring Constant: Solving the Spring Problem
To find the spring constant for a block hanging from a spring, the problem involves a 1.60 kg block and an additional 0.4 kg mass that stretches the spring by 2.00 cm. The correct approach involves calculating the total force applied to the spring, which includes the weight of both masses. The initial calculation of k as 980 N/m was incorrect due to misunderstanding the total force acting on the spring. The realization that the total force is the sum of the weights of both masses clarified the solution. Understanding this concept is crucial for accurately determining the spring constant.
rileyjah
Spring problem!
A 1.60 kg block hangs from a spring. If a 400 g body is hung from the block, the spring is stretched 2.00 cm farther. What is the spring constant?
Fsp=-kdeltas
(2.0Kg)(9.8)/(0.02)=k
k-980 N/m... which is wrong
So I am assuming that at equilibrium with m1 x=0, and when the second mass is added the total displacement is delta s=0.02 m - what am I missing?
Are you really applying 2*9.8 Newtons of additional force to the spring?
Ohhhh! It makes sense now!
Thank you!
rileyjah said:
Thank you!
A pleasure :smile:
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
