Finding sum of phasors when real components cancel out
CE Trainee
I'm working on a problem where I have to add two phasors together. The problem is, the real parts cancel out and I can't figure out how to express the phase because arctan(y / 0) isn't defined.
x1 = 10<45 degrees
x2 = 10<135 degrees
x1 + x2 = ?
x1 in rectangular form = 7.07 + j7.07
x2 in rectangular form = -7.07 + j7.07
x3 = x1 + x2 = 0 + j14.14
x3 magnitude = 14.14
x3 phase = arctan( 14.14 / 0 )?
if x3=14.14j, then it is purely imaginary and thus the vector is parallel to the imaginary plane. So the angle it makes with the real plane is just 90°.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
