Finding Tension when Mass Accelerates
  • Thread starter Thread starter allielove13
    Mass Tension
To determine the tension in the cord attached to a 0.500 kg mass at a 30-degree angle, the forces acting in both the x and y directions must be analyzed. The equations for the sum of forces are established as ΣFx = Tcos30 and ΣFy = Tsin30 - Fg. The discussion raises the question of whether the mass is moving at a constant speed, implying no acceleration. Understanding these forces is crucial for calculating the tension accurately. The focus remains on applying Newton's second law to solve for the tension in the cord.
allielove13
A mass of .500 kg is resting on the ground. Attached is a cord that makes a 30-degree angle with the horizontal. It is found that when the cord is pulled tight enough, the mass will skip along the ground without friction. How much tension is in the cord?
F=ma?
T-Fg=ma?
I have no idea how to start this..
Start with the sum of forces in the x and y direction.
So \SigmaFx=Tcos30
and \SigmaFy=Tsin30-Fg
Yeah that's right. Is this at a constant speed? Meaning no acceleration?
