Finding the accel of two objects on an incline.
  • Thread starter Thread starter Agent M27
    Incline
The discussion focuses on calculating the acceleration and tension in a system with two connected masses on a frictionless incline and pulley. The user derived the acceleration formula but encountered a signage error in their equations of motion. Correcting the equations, the final expression for acceleration is a = (m2 * g * sin(θ) - m1 * g) / (m2 + m1). The importance of choosing the correct direction for forces and acceleration is emphasized, as it affects the sign of the results. Overall, the conversation highlights the need for careful attention to detail in physics problem-solving.
Agent M27
Two objects are connected via a light string that passes over a frictionless pulley. Assuming the incline is frictionless, m1=2 Kg m2=6 Kg and \theta=55. Find the acceleration of the objects and the tension in string.
This porblem is set up with m1 hanging vertically from the pulley and m2 is resting on the inclined portion connect to the same string.
\SigmaF=ma
What I did is I found the tension in the string using the equation of motion for the mass m1/SUB]:
\SigmaF=T-mg=ma
T=m1g+m1a
I choose the acceleration to be positive here because were this a true situation this would be the direction of motion of the system.
I then wrote an equation of motion for the mass m2/SUB]:
\SigmaF= mgsin\theta-T=-ma
I choose this as the EQ of motion because mgsin\theta will provide more of a force than the tension of the rope, and I choose -ma because this portion of the system is traveling in the opposite direction.
Plugging in my equation for T I arrive at the following eq for the acceleration of the system, which is equal due to them being connected.
a=\frac{m_{2}gsin\theta - m_{1}g}{(m_{1}-m_{2})}
Basically I am wondering if I am correct, and also what is a solid method for determining the order of the terms in the EQ of motion? Thanks
Joe
You are correct. I am not sure what you mean by "the order of the terms in the EQ of motion". You have a general equation that is always true. If, when you plug in the numbers, the acceleration turns out to be a positive number, then you have chosen its direction correctly. Else, the acceleration must be in the opposite direction from the one you chose.
\SigmaF=ma
\SigmaF=T-mg=ma
T=m1g+m1a
Your equation is correct, but since you chose T as positive, T>m_1(g), then a is positive, in the direction of the net force.
You have a signage error.
Joe
Correct your signage error. The acceleration of each block is in the direction of the net force. If m_1 is assumed to move up, as a positive direction, then m_2 moves down the plane, as a positive direction. If the net force on block is assumed down the plane as positive, then 'a' is positive down the plane. If 'a' comes out negative, you assumed the wrong direction for the net force.
Oops. :redface: PhantomJay is correct. I looked at the numerator of your expression without paying too much attention to the denominator. If m1 = m2, the acceleration becomes infinite which is clearly troublesome.
So acording to your directives PhantomJay, my second equation of motion ought to be:
\SigmaF = m1gsin\theta - T = m2a
Plugging in T to solve for a I get the following:
a=\frac{m_{2}gsin\theta - m_{1}g}{(m_{2}+m_{1})}
This is the case because I choose the vertical component of gravity to be the positive, therefore net force, as well the accel is in the direction of this force, which made it positive. Thanks gents.
Joe
