Finding the Area Between Two Functions on a Given Interval
The discussion revolves around finding the area between two functions, specifically y=x^3+3x^2+5x and y=x^3+2x^2+7x, over the interval [-1,2]. Participants are exploring the concept of the "region" between the graphs and how to properly set up the integral to calculate this area.
  • Participants discuss the meaning of the "region" between the graphs and question how to determine the area when the functions intersect. There is an attempt to set the functions equal to find crossover points and a consideration of using absolute values in the integral to ensure the area is positive.
Some guidance has been provided regarding the evaluation of the integral, suggesting that it may be beneficial to break the integral into parts between crossover points. However, there is still uncertainty about the correct formulation of the second function in one of the posts, which may affect the overall approach.
There is a noted potential typo in the second function presented in one of the posts, which could lead to confusion in the calculations and interpretations of the area between the curves.
Niaboc67
Find the area of the region between the graphs of: y=x^3+3x^2+5x and y = x^3+2x^2+7x on the interval [-1,2]
I am not entirely sure what they mean by the REGION between the graphs, is this the region which encloses an area when the two functions cross over each other? not entirely sure what that means. I digress.
To find where they overlap I set them equal to each other and then isolated one entire side to zero. and got: x^2 - 2x = 0
So is this like my "main function" that I need in order to find the area. Is this the function that represents the area in between the aforementioned functions? If so, then I'd have to get the area and to get the area of any function I am guessing I'll have to take it's integral and since it's been defined on the interval [-1,2] I use those two points as a and b for my integral.
Therefore,
∫[from -1 to 2] |x^2 - 2x|dx
I know area is always positive so is it a good idea to always use absolute values when taking a functions integral? And is the dx always needed all the other problems I did seem to use that dx symbol.From that point I get a bit stuck as to what to do next
Please help
Thank you
The area between the two curves is positive regardless of which curve is uppermost at any value of x. Hence it is equal to the integral between the two x limits of the absolute value of the difference between the two functions.
In practice the easiest way to evaluate it is often to break up the integral into parts that run between consecutive crossover points. Evaluate the integral of the difference of the functions over each of those subintervals (don't put absolute value signs inside the integrals), then add up the absolute values of the results.
Niaboc67 said:
Find the area of the region between the graphs of: y=x^3+3x^2+5x and y = x^2+2x^2+7 on the interval [-1,2]
Therefore,
Please help
Thank you
Is there a typo in your second curve y = x^2+2x^2+7? Should that be y = x^3 + 2 x^2 + 7, or should it be y = x^2 + 2x + 7?
