Finding the average using integration
chris_0101
Find c such that fave = f(c)
c1 (smaller value) = ?
f(x) = 6x/(1 + x2)2
Average value (i.e. the integral) was found to be 12/5
12/5 = 6x/(1 + x2)2
12/5 = 6x/(1 + x2)2
12/5 = 6c/(1 + c2)2
12/5 = 6c/(1 +2c2 + c4)
12(1 +2c2 + c4) = 5(6c)
12 +24c2 + 12c4 = 30c
12 - 30c +24c2 + 12c4 = 0
Now, What I would do from this point on is to simply find a possible value for c, the proceed and use synthetic division to solve for the other values of c. However, this will produce 4 values for c instead of 2, which are required.
If anyone could shed some light on this question, that would greatly be appreciated
thanks
Does the problem specifically say there are only two distinct answers? If so, it is still possible to get just two distinct roots (they'll just be repeated roots). Assuming you did everything right up to this point, I would suggest trying the rational root theorem. If that fails, you could always try to quartic formula, but it's a crazy formula.
f(x) = 6x/(1 + x2)2
12/5 = 6x/(1 + x2)2
12/5 = 6x/(1 + x2)2
12/5 = 6c/(1 + c2)2
thanks
When you found the average value, you evaluated a definite integral, with limits of integration. Of the four possible values from your quartic equation, pick the one that is in the same interval as you integrated on.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
