Finding the cafpacitance, I thought it was in series
  • Thread starter Thread starter mr_coffee
    Series
The discussion centers on understanding capacitance in a system of two charged metal objects. It clarifies that the capacitance of a parallel plate capacitor is determined by its geometry, not the charge on the plates. The formula Q = CV indicates that any change in charge (Q) results in a corresponding change in voltage (V), keeping capacitance (C) constant as long as the geometry remains unchanged. The user initially misunderstood the relationship between charge and capacitance, but after clarification, they grasped the concept. This highlights the importance of recognizing that capacitance is a fixed property of the capacitor's design.
mr_coffee
Hello everyone...I'm runnning int problems on this problem:
he two metal objects in Fig. 25-26 have net charges of +62 pC and -62 pC, which result in a 14 V potential difference between them.
image is here: http://www.webassign.net/hrw/hrw7_25-26.gif
(a) What is the capacitance of the system?
4.429 pF
(b) If the charges are changed to +226 pC and -226 pC, what does the capacitance become?
wrong check mark pF
(c) What does the potential difference become?
V
If the charges are the same, i thought that ment it would be in series, which is Q = CVtotal
So i put in:
C = 226pC/14V = 16.14 pF
I also tried 0, both wrong. ANy ideas? Thanks
This isn't a question about series capacitors. The two metal objects form a single capacitor. Is the capacitance of a parallel plate capacitor dependent on the charge on the plates? Is the capacitance of a general capacitor dependent on the charge?
The capcitance of a parallel plate capacitor is dependent on the charge on the plates because the formula is. Q total = V(Ceq). Now is the capacitence of a general capacitor depedent on the charge? I"m assuming yes, the general formula is Q = CV...
The capacitance of a parallel plate capacitor is C = \epsilon_0 A /d with no mention of charge. The capacitance of a system is dependent only on the geometry which is partly why it's a useful concept. In the equation Q = CV, any change in Q is accompanied by a change in V so that C is always the same (so long as the geometry is the same). There lies the answer to your question. Once you know the capacitance of your system, it's always the same unless you change the geometry.
ohhh i c what your saying, thank you very much, i got the problem now! :)
