Finding the coefficient of friction
To find the coefficient of kinetic friction for a 100 kg bale of hay sliding 100m after falling off a truck, the initial momentum calculation was incorrectly equated to force. The correct approach involves determining the acceleration using the distance and time taken to stop, then applying Newton's second law to find the frictional force. The discussion emphasizes the importance of distinguishing between momentum and force, clarifying that mass times velocity does not yield force. Participants suggest focusing on calculating acceleration first to simplify the problem. Understanding these concepts is crucial for accurately solving the problem.
Singdasorrow
A 100 kg bale of hay falls off a truck traveling along a level road at 24.4 m/s. It lands flat on the road and slides 100m before coming to rest. Assume the acceleration is constant, compute the coefficeient of kinetic friction between the road and the hay.
F=u x N
Sum of the forces horizontally (x) = 2440 N -f = ma (acceleration is a constant)
Sum of the forces Vertically (y) = N-W=O
f= (2440)/(100a)
W= -980 so N= -980
now i plugged into f= u x N
(2440/100a)= u x -980
u= -.02a
Now i know the answer because i can see it in the back of the book, and this doesn't feel right. advice?
Don't look in the back of the book? :smile:
Can you explain where your numbers come from? What's 2440N? It would appear to have the same digits as the initial velocity :confused: but I don't see a calculation behind it.
i made the initial velocity into a force. 24.4 m/s x 100kg =2440 N
When you get an answer that looks like the calibre of a bullet, you're probably right.
Velocity is not force. Mass x Velocity is momentum, not force. They are quite different things.
Hint: Find the acceleration given the provided information. Then use Newton's second law to find the force that acted to produce that acceleration.
thank you so much! that made things so much easier for me <3
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
