Finding the Electric Force on a Rod by Linear Charge
An infinitely long, uniformly charged line with linear charge density λ1 interacts with a straight rod of length 'b' that has a varying charge density λ(y) = (λ2*b)/(y+a). To find the electric force on the rod, the approach involves calculating the integral of forces on differential charge elements along the rod. The electric field generated by the line charge is given by E = (2kλ/y), which is crucial for determining the force on the rod's charge elements. The discussion emphasizes the importance of integrating these forces while considering the varying charge density along the rod. Understanding how to apply λ2 in this context is essential for solving the problem.
thiefjack
An infinitely long, uniformly charged straight line has linear charge density λ1 coul/m. A straight rod of length 'b' lies in the plane of the straight line and perpendicular to it, with its enared end at distance 'a' from the line. The charge density on the rod varies with distance 'y', measured from the lower end, according to λ(on rod) = (λ2*b)/(y+a), where λ2 is a constant. Find the electrical force exerted on the rod by the charge on the infinite straight line, in the λ1, λ2, a, and b, and constants like ε0.
See attachment.
F = [1/(4πε0)] * [(q1 * q2)/(r^2)]
My idea is to first find the the integral of all the forces on an arbitrary charge on the rod. Then integrate the sum of that force as you go up along the rod with the different charge density.
I'm just a bit confused as to how I can utilize λ2.
If we take the line charge as the x-axis and the rod as the y axis, then the distance between two charges is r = sq[x^2 + (a+y)^2]
thiefjack said:
An infinitely long, uniformly charged straight line has linear charge density λ1 coul/m. A straight rod of length 'b' lies in the plane of the straight line and perpendicular to it, with its nearer end at distance 'a' from the line. The charge density on the rod varies with distance 'y', measured from the lower end, according to λ(on rod) = (λ2*b)/(y+a), where λ2 is a constant. Find the electrical force exerted on the rod by the charge on the infinite straight line, in the λ1, λ2, a, and b, and constants like ε0.
See attachment.
F = [1/(4πε0)] * [(q1 * q2)/(r2)]
If we take the line charge as the x-axis and the rod as the y axis, then the distance between two charges is r = sqrt[x2 + (a+y)2]
Hello thiefjack. Welcome to PF !
Do you know the expression for the Electric field due to an infinitely long line of charge?
Hi! Now that you remind me, I do remember deriving it awhile ago. Completely forgot about it.
E = (2kλ/y)j
Thanks for the reminder.
So, for any small length, dy, of the rod, with a charge of dq, the force is (E)(dq).
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
