What is the force exerted on a 380 kg piano on a ramp with an incline of 27*?
  • Thread starter Thread starter lemonlee
    Force
The discussion centers on calculating the force exerted by a man pushing a 380 kg piano on a 27-degree incline, where the piano slides 3.9 meters without accelerating. The correct force exerted by the man is approximately 1700N, derived from the gravitational force component acting on the piano. Participants clarify that since the piano is not accelerating, the net force is zero, meaning the man's force balances the gravitational pull. A misunderstanding about the application of trigonometric functions and mass multiplication was addressed, leading to the correct interpretation of the problem. The conversation emphasizes the importance of correctly applying physics equations and understanding force balance in static scenarios.
lemonlee
a 380 kg piano slides 3.9m down a ramp with an incline of 27* and is kept from accelerating by a man pushing parallel to the incline. Find the force exerted by the man, the work done by the man on the piano, the work done by the force of gravity, and the net work on the piano. Ignore friction.
F=ma
W=F*d*cos27
Once i get the force exerted by the man, I know what to do, I just can't get the right answer. I drew out a force diagram and then tried the equation, but can't get to the given answer of 1700N
F=ma
W=F*d*cos27
I think you've assigned the wrong trig. function to the angle. Using \sin(3\pi/20), you get 1692N, which, after keeping 2 sig. figg., results in 1700N...
so I can assume that the net force is zero because the piano is accelerating, right? wouldn't that just make the force exerted by the man 4.45N?
I think i might be missing a step
...RIght, well, because the piano isn't accelerating, the sum of the forces is zero. So, the force exerted by the man was imposed after motion began and is equal and opposite that of the x-component of gravity acting upon the piano.
oh i see what i forgot, I didn't multiply by the mass, I was just solving for F=a...
oops!
thank you for explaining that :)
oops!
You're very welcome.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
