Finding the frequency of very small oscillations
The discussion focuses on finding the frequency of small oscillations around the equilibrium distance of two particles in a potential well. The equilibrium distance was determined to be r_equilibrium = 2^(1/6)*a by setting the derivative of the potential U(r) to zero. To find the frequency of oscillations, a Taylor expansion was used to approximate the potential as a parabola, leading to the force equation F = -k(r-r_0). The spring constant k was calculated as 9*2^(2/3)*E_0/a^2, resulting in the angular frequency ω = (3*2^(1/3)/a)*sqrt(E_0/μ). The discussion concludes with satisfaction regarding the derived expression for frequency.
Bjarni
Find the frequency of very small oscillations around the equilibrium distance
U(r) = E_0[(a/r)^12- (a/r)^6]
So I'm working on this home assignment that has numerous segments. Firstly, I was asked to find the equilibrium distance between two particles in a potential well described by U(r).
I did that by setting U'(r) = 0 and came out with r_equilibrium = 2^(1/6)*a.
Now, I'm being asked to find the frequency of very small oscillations around r_equilibrium and I'm honestly lost. I think I only need a small push in the general direction of the solution because as of now I don't really know where to start.
Thanks in advance.
For very small oscillations you can approximate the potential by a parabola.
Thanks.
I used a Taylor-expansion and set F = -k(r-r_0) = -dU/dr.
Got k = 9*2^(2/3)*E_0/a^2
and since ω = sqrt(k/μ), I ended up with ω = (3*2^(1/3)/a)*sqrt(E_0/μ) which I feel pretty good about.
Sorry for my lack of LaTex skills..
Likes mfb
