Finding the last corner of a square
  • Thread starter H4NS
  • Tags
    Square
In summary: Yeah, I think that's right. It needs to be long enough so that the sum of the lengths of the vector's components is equal to the diagonal's length.
H4NS
Show that there is a C point to these points A(-2|2|3), B(2|10|4) and D(5|-2|7), so that the quadrangle ABCD a square is. Determine the coordinates of C.
All I have done is measure AC, CD and BC, which are 9, 9 and 12.78. But how do I get the C point from this data?
Thanks in advance
Thanks in advance
The length of AB = 9 by calculation and the length of AD = 9 by calculation, so AD and AB are adjacent sides, with BC a diagonal of length 12.78. That means AC must be a diagonal and its length can't be 9. Something is wrong with your figures.
Oh Sorry, I meant AC = 12.78, since it's a square, BC and CD must be 9 too.
Usually when you give a quadrilateral ABCD that would give the vertices in order as you go around the square. In this case with AB and AD adjacent sides, the order around the square can't be ABCD. Is that what you meant to have or do you still have typos? It might be good to state carefully exactly what you are given.
Have you studied vectors and how to manipulate them?
This is what I mean
I have also missed some classes, and that's why I require help from you
H4NS said:
This is what I mean
You didn't answer my question whether you have studied vectors. Think about what you would get if you add the vectors AB and AD. What direction would it point?
AB+AD would point in the direction of AC, but I don't know those vektors, I only know the points ABD
I know how to perform certain operations with vectors, but as I said, I missed some classes, and probably the key to resolve this problem
To get a vector between points P and Q you subtract the coordinates of P from the coordinates of Q to get the components of the vector PQ.
Oh man, thanks a lot, then I suppose I have to do the following:
AB: (2-(-2)|10-2|4-3) AD: (5-(-2)|-2-2|7-3)
Then AC: (4+7|8-4|1+4)
Thus the C point is (11|4|5), right?
But this is somehow wrong because when doing calculating CD or BC I get don't get 9!
What am I doing wrong?
No, that is not the point C. It is a vector pointing towards C. You have a vector in the right direction, but its length is whatever it came out. How long is it? How long does it need to be to fit the diagonal? How do you change its length?
It's length is as far as I know is |C|, 12.72, which is the measure of the diagonal
OK, so it is the right length. Now, if you are at the point A, how do you use that vector with the coordinates of A to figure out the coordinates of C? And, by the way, it would be best to use exact values instead of decimal approximations if you want the exact coordinates of C.
Thank you very much, I got it
I did it like this: AC(11|4|5) = (cx-(-2)|cy-2|cz-3), then separated it in 3 simple equations: cx+2=11; cy-2=4; cy-3=5. And got C(9|6|8).
Also, you kind of implied with your last post, that it could be measured with help of the vector's lenght, how?
When you added the two vectors from the sides to get a vector in the direction of the diagonal, you needed to check its length to make sure it is the right length for the diagonal. In this case it checked OK. Had it not been the right length, when you added its components to the coordinates of A, you wouldn't have gotten the coordinates of C.
You are making things much more complicated than they need to be. Just look at the displacement from A to B; that is, starting from A, how do you reach B? You start from x = -2 at A and get to x = +2 at B, so you go 4 units in the x-direction. You start from y = 2 at A and get to y = 10 at B, so go 8 units in the y-direction. You start at z = 3 and end at z = 4, so go 1 unit in the z-direction. So, AB = (4,8,1). Thus, in order that ABCD be a parallelogram you need DC = AB --- draw a picture to see this --- so DC (4,8,1), hence C = D + DC = (5,-2,7) + (4,8,1) = (9,6,8).
RGV
Related to Finding the last corner of a square
1. How do you find the last corner of a square?
To find the last corner of a square, you can use the Pythagorean theorem. First, measure the length of two sides of the square. Then, square each of those lengths and add them together. Finally, take the square root of the sum to find the length of the missing side, which is the last corner of the square.
2. Can you find the last corner of a square without using the Pythagorean theorem?
Yes, there are other methods to find the last corner of a square. One way is to use the properties of a square, where all sides are equal in length and all angles are right angles. By measuring the length of one side and the angle between that side and the unknown side, you can use trigonometry to find the missing length.
3. What if I only know the perimeter of the square, can I still find the last corner?
Yes, you can still find the last corner of a square if you know the perimeter. Since a square has four equal sides, you can divide the perimeter by 4 to get the length of one side. Then, you can use this side length to find the missing length using the methods mentioned in the previous questions.
4. Is it possible for a square to have more than one last corner?
No, a square can only have one last corner. The last corner is the point where the two sides of the square meet to form the final angle. Since a square has four equal sides and all angles are right angles, there can only be one point where the two sides meet.
5. Can I find the last corner of a square if I only know the area?
Yes, you can find the last corner of a square if you know the area. First, you can use the formula for the area of a square, which is side length squared. Then, you can take the square root of the area to find the length of one side. Finally, you can use this side length to find the missing length using the methods mentioned in the previous questions.
  • Precalculus Mathematics Homework Help
