How Do You Calculate the Length of a Wire in a 60W Incandescent Bulb?
  • Thread starter Thread starter UnknownSoldier02
    Length Wire
To calculate the length of the wire in a 60W incandescent bulb, the resistivity is crucial but not provided, leading to confusion about which equations to use. The relationship between resistivity, resistance, area, and length is highlighted, but two variables are missing, complicating the calculation. The discussion suggests considering the wire as a blackbody radiator, which may relate to the Stefan-Boltzmann equation. This approach could help in deriving the necessary parameters for the calculation. Understanding these concepts is essential for accurately determining the wire length in the bulb.
UnknownSoldier02
Finding the length of a wire of incandescent light bulb.
N/A
How to find the length of a wire of a 3000 Kelvin incandescent light bulb that produces L = 60W of power. The diameter of the wire is 0.00005m.
I'm quite confused, as the resistivity of the bulb isn't given so I'm not sure what equation to use as resistivity = resistance × area / length does not seem to work because I'm missing 2 variables.
UnknownSoldier02 said:
Homework Statement: Finding the length of a wire of incandescent light bulb.
Homework Equations: N/A
Think of the wire as a blackbody radiator.
Would it be related to the Stefan-Boltzmann equation in some way?
Yes.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
