Finding the limit of lim_(h-->0) (f(1+h,2) - f(1,2))/h
  • Thread starter Thread starter TSN79
    Limit
To find the limit of (f(1+h,2) - f(1,2))/h as h approaches 0, start by substituting (1+h, 2) into the function z=2x^3+xy^2-6y. Calculate f(1+h, 2) and f(1, 2) using these values. Expand the resulting polynomials, perform subtraction, and look for cancellation of terms. Divide the result by h and then take the limit as h approaches 0. This process effectively involves finding the partial derivatives at the specified point.
TSN79
I have a function z=2x^3+xy^2-6y
I need to find the limit of the following:
\lim_{\substack{h\rightarrow 0}} \frac{f(1+h,2)-f(1,2)}{h}
I don't know if the function is required to calculate this limit, so I just wrote it as well. I just need some hint on where to begin, and how to approach this type of limit...
Replace x and y with the specified values, expand your polynomials, subtract, look for cancellation and divide the result by h - then take your limit! :-)
Won't I need to find the partial derivatives?
That's exactly what you're doing.
Hmm...I should replace x and y with the specified values, those are 1 and 2 ?
If I do that in the function then I get the value -6. Where does that leave me?
No, (x, y) = (1, 2) for f(1, h) but (x, y) = (1+h, 2) for f(1+h, 2).
