Finding the matrix with respect to two bases
  • Thread starter Thread starter Niles
    Bases Matrix
Niles
If I am giving a matrix A representing the linear transformation L(x) = Ax, then A is the matrix-representation of L with respect to the basis elements in the vector-space S (standard).
If I am now given another vectorspace V by the matrix V, and I want to find the matrix B representing L with respect to the bases S and V, I use:
B = V^(-1) * S.
Is what I wrote correct?
Thanks in advance.
Sincerly, Niles.
B = V^(-1) * S.
Thanks in advance.
Sincerly, Niles.
I don't know what you mean by "given another vectorspace V by the matrix V". First, since you were able to write L as a matrix using one basis for S, the L must be a transformation from S to itself- you can't be "given another vector space V". Second, since a vectorspace and a matrix are different objects, "vectorspace V" and "matrix V" makes no sense. I suspect you mean that you are given a new basis (as columns of a matrix?) for the same vectorspace S. The standard way of representing a linear transformation from U to V, as a matrix, for given bases of U and V is: Apply the transformation to each basis vector of U in turn. Right the result in terms of basis V. The coefficients give a column of the matrix.
For example, suppose L:R2-> R2 takes basis vector <1, 0> to <4, 2>. If {<1, 1>, <1, -1>} is another basis, then <4, 2>= 3<1,1>+ 1<1,-1>. The first column is <3, 1>.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
