Finding the particular anti derivative when given f'(x) and TWO f(value)s
  • Thread starter Thread starter skyturnred
    Derivative
skyturnred
Here is the question directly from the book:
f'(x)=x^(-1/3), f(1)=1, f(-1)=-1, find f(x).
So there are about ten of these types, and I am very confused. I am confused because if you solve for f(x) with f(a) you get a different value for c than if you solved for f(b).
So finding f(x) I get f(x)=(3/2)x^(2/3) + c
If I make f(x)=1 and x=1, I get the value of c to be -1/2
But if I make f(x)=-1 and x=-1, I get the value of c to be -5/2..
Thank you so much for your help in advance!
Notice that f(0) is not defined. So you actually have two branches. So your function can be described as
f(x)=\left\{\begin{array}{c}(3/2)x^{2/3} + c_1 ~\text{if}~x>0\\ (3/2)x^{2/3} + c_2 ~\text{if}~x<0 \end{array}\right.
f(x)={(3/2)x2/3+c1 if x>0(3/2)x2/3+c2 if x<0
So whenever f'(0)=DNE, the function f(x) can be written as a piecewise function?
Indeed!
Do notice that you proved that the anti-derivative of a function is unique up to a constant. But you only proved that for functions that exists everywhere on an interval. If a function does not exist in a point, then the result isn't true anymore!
micromass said:
Indeed!
OK, thanks again! You helped tremendously.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
