Finding the pressure at a given height?
The discussion centers on deriving air pressure at a given height, with a focus on the relationship between pressure and density. The user initially attempts to use integrals to express pressure but struggles due to the interdependence of density and pressure. The Barometric formula is introduced as a solution, which assumes constant temperature, although the user notes that temperature varies with altitude. The conversation highlights the complexity of atmospheric pressure variation and suggests that a more accurate model would require considering temperature changes across different atmospheric layers. Ultimately, the discussion emphasizes the need for a mathematical relationship that accounts for these variables.
21joanna12
I am having trouble trying to derive the air pressure at a given height. So far, I have considered a 1m^2 patch of area, and the pressure is the weight of all of the air above this patch.
So P= \int_R^{\infty}g(x)\rho(x)dx
So P= GM\int_R^{\infty}\frac{1}{x^2}\rho(x)dx
But then I don't know what to do because the density will depend on the pressure at a given point? So I feel like I am going around in circles...
Any help will be much appreciated! :) I have a feeling that I am missing something really obvious.
EDIT: here I was finding the pressure at ground level, hence the limits of integration, although I would find a general expression by changing the lower limit from R to a given height R+h.
Can you think of any relation between density and pressure? Perhaps that would allow a change of variables?
Likes 21joanna12
Like a lot of natural things, the variation of atmospheric pressure with altitude is quite complicated, due to a variety of factors:
http://en.wikipedia.org/wiki/Atmosphere_of_Earth
The mass density of the atmosphere varies with altitude in a roughly linear fashion up to about 70 km above the Earth's surface.
The problem you are trying to solve, the variation of atmospheric pressure with altitude, leads to what is known as the barometric formula:
http://en.wikipedia.org/wiki/Barometric_formula
and a derivation of this relationship is included in the article.
Likes 21joanna12
Thank you for the link! Although there is something that is bugging me: in the Barometric formula, it is assumed that the temperature is constant, but it actually varies with altitude? I suppose it doesn't really vary in a predictable way because of the different layers of the atmosphere, so nothing can really be done about this unless you considered each temperature section separately and summed them all up to find the total pressure?
There is a range of altitudes for which the Barometric formula is applicable. The Barometric formula is sometimes called the Isothermal atmosphere because it assumes constant temperature in the various layers of the atmosphere to which it is applicable.
In the Wiki article, there is a table which gives the values of various constants for the six different layers of atmosphere below 71 km altitude. In the article on the Atmosphere of Earth, there is a plot which shows that the variation on temperature with altitude is quite nonlinear. The temperatures used in the table agree pretty closely with the graph for the reference altitudes for each layer.
I think the best you can say is that the Barometric formula is an attempt to develop a mathematical relationship between atmospheric pressure and altitude using a few key data points.
Likes 21joanna12
The differential equation that applies is:
\frac{dp}{dz}=-\frac{p(z)M}{RT(z)}g(z)
The solution to this equation is:
$$p(z)=p(0)e^{-\frac{M}{R}\int_0^z{\frac{g(z')}{T(z')}}dz'}$$
where z' is a dummy variable of integration. This equation takes into account the dependence of g and the dependence of T on altitude z. So, to apply it, you need to know how g and T vary with altitude. The dependence of T on z comes from observational data.
Chet
Likes 21joanna12
  • · Replies 50 ·
  • · Replies 67 ·
  • · Replies 20 ·
18K
