Finding the resistance, magnetic flux, and current of a loop section
In summary, based on the angle, the loop's resistance is 1.88E-2*θ and the magnetic flux through the loop is 2.88E-2*θ.
arghphysics
...based on the angle.
Figure 30-78 shows a wire that has been bent into a circular
arc of radius r = 24.0 cm, centered at O. A straight wire OP can be
rotated about O and makes sliding contact with the arc at P.
Another straight wire OQ completes the conducting loop. The
three wires have cross-sectional area 1.20 mm2 and resistivity
1.70 10^-8 Ωm, and the apparatus lies in a uniform magnetic
field of magnitude B = 0.150 T directed out of the figure.Wire OP
begins from rest at angle θ = 0 and has constant angular acceleration
of 12 rad/s2. As functions of θ (in rad), find (a) the loop’s
resistance and (b) the magnetic flux through the loop. (c) For what
u is the induced current maximum and (d) what is that maximum?
The image of the problem: http://i.imgur.com/TJVSmAK.jpg
Flux = ∫BdA
ε = -d(Flux)/dt
B = μ_0*i/2pi*r
For part a), I solved using the resistivity equation, rho = R*A/l, with l = 2*r+ rθ, and solved for R.
For part b), I started with Flux = ∫BdA, took B outside of the integral (since it is uniform). I went to the integral solution for a circle, so I could just plug in the angle to get the area of the circle, which gave me 0.24^2/2 * θ = 2.88E-2*θ. That's my guess of where to go, anyhow.
What's throwing me off is I'm given the angular acceleration of the wire itself. I am at a loss of where to go. From worked out problems in the book, the velocity of the loop itself figures into the problem. But that's usually because they're trying to find the emf of the loop itself. Am I overthinking this second part? Should the solution just be Flux = B*2.88E-2*θ?
Looks good to me. The angular acceleration of the wire is only important when you have to figure out what the rate of change of the magnetic flux is with respect to time.
I'm confused about part c) now. Hah.
I'm certain I have to take the equation I found for the flux and take the derivative of that to find the induced EMF. But all I have is the angular acceleration for the wire, which is 12 rad/s. So, the double integral of that is 6t^2. I put that into the equation I found for flux based on angle, take the derivative of it and now I have an equation for EMF based on time.
If I take the equation I found for resistance, and replace theta with 6t^2 and divide EMF/R, I can find the induced current. Correct? All I have to do is take the derivative of that, set to zero and solve?
Afterwards, I can take what that equation gives me for t, put it into theta = 6*t^2 and solve.
Could you include a picture of the problem statement given in the book?
All that sounds good.
I wasn't quite sure what you meant by u in this:
arghphysics said:
(c) For what u is the induced current maximum
Okay, so I think I went down the wrong track. I got 2 radians for when the current is at a maximum, but when I solved for current I got 6.0E9 Amps which seems a tad high.
Your result for θ matches mine, but your value for the current does not :wink:
I usually convert all given values to SI base units before I plug anything in. You probably just need to go through them again.
Okay, I found my mistake. I am not used to this new scientific calculator, so it did something I wasn't expecting. The current is now approx 6.0E-15, which sounds more realistic.
Thank you so much for your help!
Hmm, I get a maximum value of approximately 2.20 A.
Argh.
If you want to be sure, you can write out your expression for the current and the values you plug into it so we can go through it together.
How is that? EMF has an approx magnitude of 1E-2, and R has an approx magnitude of 1E-12. Any value of t I enter in will give me something around 1E-15.
i = ε/R
ε = -5.18E-2*t
R = 4.8E-12 + 1.44E-11*t^2
t = 0.577439 s
That is what I have.
It helps if we start with the symbolic expression. Does this:
[tex]
i(t) = \frac{\alpha \, r A_w B \, t}{\rho(\alpha t^2 + 4)}
[/tex]
where ##A_w## is the cross-sectional area of the wires and ##\alpha## is the angular acceleration of ##OP##, match yours?
No. I have
i(t) = B*r^2*θ'*A / 2ρ(2r+rθ)
For θ', I have 12*t, and θ I have 6t^2.
I'm not sure why you have angular acceleration *and* time in the equation.
arghphysics said:
No. I have
Sorry, ##\alpha## is the constant value of angular acceleration.
If you insert your expression for θ' and θ into i(t) and simplify a bit, your expression will match mine.
Are these:
[tex]
r = 0.24 \, \mathrm{m}\\
A_w = 1.20 \times 10^{-6} \, \mathrm{m^2}\\
\rho = 1.70 \times 10^{-8} \, \mathrm{\Omega \cdot m}\\
B = 0.150 \, \mathrm{T}\\
\alpha = 12 \, \mathrm{\frac{rad}{s}}
[/tex]
the values you're substituting into your expression for i(t)?
It wasn't originally. I converted the area of the wire incorrectly. I simply had 1.2E-3, instead of E-6.
Assuming t = 0.577439 is the correct time, I ran the equation again with the correct wire area size and I'm still getting a ridiculous number for i.
I'm beginning to think I don't know how to use this calculator, and how it wants expressions entered into it.
I found one error on my part (didn't include r^2 in the top expression), and now my answer is close to what yours is, at i = 3.78 A.
Also, I've been using the wrong time as well. I now have the answer you got. Woof.
Thank you again!
You're welcome.
What is resistance and how is it measured?
Resistance is the measure of a material's ability to resist the flow of electrical current. It is measured in ohms (Ω) and can be calculated using Ohm's law, which states that resistance is equal to the voltage divided by the current.
What is magnetic flux and how is it calculated?
Magnetic flux is the measure of the strength of a magnetic field passing through a given area. It is calculated by multiplying the magnetic field strength by the area perpendicular to the field. The unit of measurement for magnetic flux is the weber (Wb).
How can the current of a loop section be determined?
The current of a loop section can be determined using the formula I = Φ/ R, where I is the current, Φ is the magnetic flux, and R is the resistance. This formula is derived from combining Ohm's law and Faraday's law of induction.
What factors can affect the resistance, magnetic flux, and current of a loop section?
The resistance, magnetic flux, and current of a loop section can be affected by several factors, such as the material of the loop, the size and shape of the loop, the strength of the magnetic field, and the temperature of the loop. Changes in any of these factors can impact the overall values.
Why is it important to find the resistance, magnetic flux, and current of a loop section?
Knowing the resistance, magnetic flux, and current of a loop section is important in understanding the behavior of electrical circuits and electromagnetism. These values can also be used to calculate other important parameters, such as voltage and power, and can aid in troubleshooting and designing electrical systems.
