What is the formula for finding the speed of ions in a heated plasma?
  • Thread starter Thread starter Drakkith
    Ions Speed
To find the velocity of positive ions in a deuterium plasma heated to 15 keV, the kinetic energy formula v = sqrt(2E/m) can be used. The mass of deuterium is approximately 3.3444 x 10^-27 kg, and converting 15 keV to joules yields about 24032.65 x 10^-19 J. When applying the formula correctly, the resulting velocity should be around 1 million m/s. Additionally, it's noted that using energy units in eV can simplify calculations, allowing for results in terms of the speed of light. Proper conversion and application of these formulas are crucial for accurate results.
Drakkith
Mentor
First off, this isn't a homework problem, but something I am trying to figure out on my own. I figured there wasn't a better place in the forums to ask though.
I'm trying to find the velocity of positive ions in a deuterium plasma that is heated to 15keV.
I'm not sure of the correct ones to use. I've tried the following.
1 eV = 1.602176487(40)×10−19 J
Ke=1/2MV*2
I've found the mass of dueterium as about 3.3444 x 10*-27 Kg.
Converting 15keV to J gives me 24032.647305 x 10*-19 J.
Plugging this into the kinetic energy formula doesn't work very well, as i get a V of less than 1. Am I not converting 15keV to the right amount of joules? I don't know if the temp in eV would convert directly to Joules.
Thanks!
Better check that calc. Doing v = sqrt(2E/m) you'll have 10^-15 in the numerator and 10^-27 in the denominator. That gives the square root of 10^12 or roughly 1 million m/s for the velocity.
Just to make an observation. If you use v = \sqrt{2E/m}, you can leave everything in eV to obtain the speed in units of c.
It's been a long time since I did any serious math. Whats the rules again when you have to mulitply and divide with unlike exponents?
To divide powers with the same base, keep the same base and subtract the exponents.
10^3 divided by 10^-2 is 10^(3 - -2) = 10^(3+2) = 10^5
yes, since when you report the mass in energy units you refer to the rest energy of the particle:
<br /> E_{0} = m c^{2}<br />
and the formula is:
<br /> v = \sqrt{\frac{2 K}{m}} = \sqrt{\frac{2 K c^{2}}{m c^{2}}} = c \, \sqrt{\frac{2 K}{m c^{2}}}<br />
Here K is the kinetic energy.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
