Finding the Time in a SHM Problem
  • Thread starter Thread starter darkblue
    Shm Time
The discussion revolves around calculating the time it takes for a bus to stop after being snagged by a Super Bungee cord, modeled as simple harmonic motion (SHM). Participants initially miscalculated the period of the system, with some confusion about the correct formula and the implications of initial velocity on stopping time. The correct period T was identified as approximately 14.8 seconds, leading to further discussions about the time intervals corresponding to different positions in SHM. Clarifications were made regarding the relationship between the equilibrium position and local maximum, emphasizing the need to understand the fractions of the period involved. The conversation highlights the importance of accurately applying SHM equations and understanding the physical context of the problem.
darkblue
Bungee Man is a superhero who does super deeds with the help of Super Bungee cords. The Super Bungee cords act like ideal springs no matter how much they are stretched. One day, Bungee Man stopped a school bus that had lost its brakes by hooking one end of a Super Bungee to the rear of the bus as it passed him, planting his feet, and holding on to the other end of the Super Bungee until the bus came to a halt. (Of course, he then had to quickly release the Super Bungee before the bus came flying back at him.) The mass of the bus, including passengers, was 1.20×104 kg, and its speed was 21.2 m/s. The bus came to a stop in 50.0 m.
B) How much time after the Super Bungee was attached did it take the bus to stop?
x = 50 m
m = 1.20x104 kg
v = 21.2
k = 2160 N/m (calculated in Part A of the question. I used the conservation of energy to figure it out)
T = 2pi x sqrt(k/m)
v = -Awsin(wt)
x = Acos((2pi/T) x t)
I solved this problem by finding the period T, and dividing this by 2, since the point at which the bus stops would be equal to half of the period in SHM. Now I'm starting to wonder whether the initial velocity of the bus would cause the bus to actually take longer than T/2 to reach that point where it stops. I even tried using simple kinematics to solve this problem, but that didn't work either. For T, I got 14.8, and divided it by 2 to get 7.40, which is wrong...does anyone know what I'm doing wrong?
Once the spring has reached a standstill and commences to retract, the SHM eqns should work. It makes no difference how that distance from equilibrium was reached.
From your comments, I believe you may have computed the swing back time, but neglected the time required to slow the bus?
Edit: on second thought, 1/2 T is right--I'll check the K computation.
In SHM the velocity reduces from maximum to zero in time T/4 s.
Right, I guess i misread the question as well, but the T seems too large:
I get .43(2*pi) for a complete period?
I double checked my calculations and I'm getting that too. So now I just divide this value by 4?
I divided it by 4 and got 0.67, which is incorrect...
I have a feeling I only have to divide it by 2. Can someone verify this?
There is an error in the formula for the period in the first post.
It is
$ T= 2\pi\sqrt{\frac{m}{k}} $
(and not k/m)
It gives T= 14.8 s with k=2157 N/m
The time from the position where the spring is not stretched to the maximum extension is T/4.
AHH woops...thanks so much for noticing that! :)
Hey,
Ive been working on this problem and i used T=2pi * root k/m and got 14.81..im not sure where to go from here to get the time after though. i tried using the v=-Asinwt equation and got 5.77 which is wrong. Any help is greatly appriciated.
Thanks in advance!
We're looking for the period of time starting when the bus is first snagged by the bungee cord, and ending when the bus is at its maximum distance. At the former instant, the bus is at "position zero." It is at the same position as the bungee cord's anchors, and therefore feels no net force due to the cord. In other words, it is at the equilibrium position. The latter instant corresponds to the position of local maximum for the bus. We can interpret these points using the graph of the position function:
x(t) = A cos( \frac{2 \pi }{T} t )
The time interval we want is the one between an equilibrium position (i.e. a zero) and a local maximum on this graph. You should be able to determine what fraction of the period it is from this.
I tried using that equation, however we do not have the amplitude, leaving us with two unknowns in the equation :S
