Finding the unitary matrix for a beam splitter
7 replies · 5K views
phb1762
(a) Construct the matrix for a beam splitter with a 70% reflectivity.
(b) By applying this operation twice, calculate the output state of a single photon in the input. Hint: the second beam splitter can be oriented in two different ways.
1) Born rule for bipartite states ( as there are 2 possibilities for input and two probabilities due to the 70:30 beam splitter)
2) ket space equations
Hello,
I have some trouble understanding how to construct the matrix for the beam splitter (in a Mach-Zehnder interferometer).
I started with deciding my input and output states for the photon.
240971
I then use Borns rule, which I have attached below:
240970
To get the following for the state space of the photon going in:
240974
But in the end, I end up with a matrix that doesn't appear unitary:
240975
I don’t know where I’m going wrong. We’ve only just started doing Quantum and the lectures are quite difficult for me to understand. I would appreciate any help and advice as I really would like to be able to do these types of questions as I suspect they will be in my exam!
Thanks everyone in advance and sorry for the many photos!
Think again about what happens at BS1 when coming in from the top.
I really don’t understand where I’m going wrong, I thought that going in from the top should be inverse of the going in from the left?
If only BS1 is present, coming in from the top, was is the probability that the outcome is right?
Ah, so something like this:
241116
Yes. You can check now that ##U_\mathrm{BS}## is unitary.
Thank you so much for your time, that was very helpful!
Without looking at it in detail, if it is a dielectric beamsplitter with an anti-reflection (AR) coating on one side, the Fresnel coefficients for the reflectivity will be ##\rho= \pm \sqrt{.70} ## and the transmission (composite) will be ## \tau=\sqrt{.30} ## for both paths. The matrix method is simply a way to express the linear transformation that occurs with the Fresnel coefficients for the electric field amplitudes of the electromagnetic wave for transmitted and reflected components.
I was unaware of the matrix method for beamsplitters (developed by Schwinger) when I wrote this Insights article: https://www.physicsforums.com/insights/fabry-perot-michelson-interferometry-fundamental-approach/
If you can follow the article, you will then understand what the matrix method does.
