Finding the value of the coefficient of elasticity for a 1D collision.
The discussion revolves around calculating the coefficient of elasticity for a 1D collision between two bodies of different masses, where two-thirds of the kinetic energy is lost. The participants derive three key equations based on conservation of momentum, kinetic energy loss, and Newton's law of restitution. They find that their calculations consistently yield negative values for the coefficient of elasticity, indicating a possible error in their approach. By substituting expressions derived from their equations, they can solve for the coefficient of elasticity accurately. The conversation emphasizes the importance of careful algebraic manipulation to avoid sign errors in the calculations.
Lemansky
Hi all first post. Myself and my friends are very much stumped by this question. Any help would be much appreciated!
A body with mass m collides directly with a body of mass 3m. If two thirds of the original kinetic energy is lost, find the coefficient of elasticity for this collision.
Conservation of momentum: m1u1+ m2u2=m1v1+m2v2.
Newton's empirical law: v2-v1= -e(u2-u1)
Loss in kinetic energy: (1/2)m1(u1)^2+(1/2)m2(u2)^2=(1/2)m1(v1)^2+(1/2)m2)v2)^2.
Using all the info given and giving the sphere of mass m initial velocity u and final velocity v1, and the sphere of mass 3m initial velocity of 0 and a final velocity of v2 we derived three equations, as follows,
1) u=v1+3v2 from the conservation of momentum.
2)u^2=3(v1)^2+9(v2)^2 from the fact that the final kinetic energy equals a third of the initial kinetic energy,
3)(v2-v1)/e =u from rearranging Newton's empirical law.
By squaring out equation 1 and setting it equal to equation 2 we found that v1=3v2.
No matter which way we approached the problem the same equations always fell out and by juggling them around we were able to get values for e with one problem, they were always negative (but had they been positive they would have been realistic). We are probably making some simple mistake with signs or we're cancelling out somehting which can't be canceled but we really are stuck.
Any help much appreciated!:smile:
From the equations you derived, you can solve for the coefficient of elasticity. From equation 1, you have v1 = u-3v2, and from equation 3, you have u = (v2-v1)/e. Substituting the expression for v1 into equation 3 and rearranging, you get e = (v2-u+3v2)/u = (4v2-u)/u. Using the expression for u from equation 2, you can substitute it into the equation for e and solve for v2. Then, substitute the expression for v2 into the equation for e to get your answer.
