Finding the Work done on a Ride?
  • Thread starter Thread starter ilovemynny
    Work Work done
To calculate the work done on a child riding the Batwing at Six Flags, the correct formula is W = F * s * cos(θ), where F is the force, s is the distance, and θ is the angle of incline. The force is determined by multiplying the child's mass (43 kg) by gravitational acceleration (9.81 m/s²), resulting in 421.83 N. The work calculation initially attempted used the cosine of the incline angle, but the correct approach involves using the sine function to find the height. A free body diagram is recommended to clarify the direction of forces and the angle used in calculations. Understanding the distinction between using sine and cosine in this context is essential for accurate work calculations.
ilovemynny
The lift incline on the Batwing ride at Six Flags America, is 66.2 m long and has an incline of 32.0 degrees. How much work is done to take a 43 Kg child to the top of the hill?
W = FsCos
I don't know if this is the right formula to use!
If this is the right formula to use would the solution go like this:
F = 43 Kg x 9.81 m/s/s
F = 421.83N
W = FsCos
W = 421.83N x 66.2 m x (Cos 32)
W = 23681.8669
W = 24000 J
Is this right, or did I do this wrong? If I did do this wrong can someone help me?
You should do a free body diagram. You have a problem in how You chose your angle or do your trig.You can also do the problem using energy methods.
wait wait what if I did this instead?
W = 421.83N x 66.2 m x (Sin 32)
This is correct but do you understand why? Can you solve it using energy?
actually no >.> my previous questions used the sin when finding height
but when i looked up the formula for work with angles it gave me cos.
can you tell me why?
Ok. W=F* cos(a)*s is the definition of work when we have an abject moving in a straight line. It means that work is equal to the component of the Force acting on the same direction as the objects movement.If you have force acting in the same direction as the object moves the angle is 0 and W=Fs if the force acts at a angle W=F* cos(a)*s.The thing is that you don't use this formula to plug random things in it.You must figure out what is the displacement "s", what is the direction of the objects movement and at what angle "a" does the force does with that direction. You do that by making a Free Body diagram.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
