Finding the work done to remove a dielectric slab.
To find the work done in removing a dielectric slab from a charged capacitor, the initial energy stored with the dielectric is calculated using Uo = 0.5 * Qo^2 / Co. After removing the dielectric, the new capacitance is Co/k, and the voltage increases to V = kVo. The energy stored without the dielectric is U = Uo/k. The work required to remove the dielectric is the difference between the initial and final energies, leading to the formula Work = U - Uo. The calculations indicate that the energy stored in the capacitor changes, necessitating a careful reevaluation of the energy expressions used.
Cisneros778
A 6.8-nF parallel plate capacitor with a sheet of Mylar (κ = 3.1) filling the space between the plates is charged to a potential difference of 160 V and is then disconnected. (The initial capacitance including the dielectric is 6.8 nF.)
(a) How much work is required to completely remove the sheet of Mylar from the space between the two plates?
Uo = (.5)*Qo^2/Co
U = Uo/k
Work = U - Uo
I solve for Qo using Co = Qo/Vo
Co*Vo = Qo
Uo = (.5) * (Co*Vo)^2/Co
this simplifies to
Uo = (.5) * Vo^2 *Co
Plugging in the values I get
Uo = (.5) * 160^2 * 6.8*10^-9
Uo = 8.7*10^-5
U = 2.81*10^-5
Work = (+ or -)5.896*10^-5 J
My answer is wrong when I enter it in the system. I'm not sure what to do from here.
You may want to check your formula U = Uo/k. When the dielectric is pulled out, work will be done. Energy stored in the dielectric is going to end up back in the capacitor.
If Co is the initial capacitance, then the new capacitance without the dielectric will be Co/k. If the initial charge is Q = VoCo, then after the dielectric is removed the voltage will rise to V = kVo. If you plug the expressions for the new capacitance and new voltage into the energy expression you should find that E = k(1/2)CoVo2.
