Finding the x range using curvilinear motion
The discussion focuses on determining the car's acceleration at point B, given its speed function and the hill's equation. The user initially struggles with finding the x range but eventually resolves the issue by applying the integral of the square root of one plus the derivative of the hill's equation. This approach allows them to calculate the necessary values for velocity and acceleration. The problem involves understanding curvilinear motion and the relationship between position and speed. Ultimately, the user successfully finds the solution by using the correct mathematical methods.
imataxslave
The car passes point A with a speed of 25 m/s after which its speed is defined by V = (25-0.15s)m/s. Determine the magnitude of the car's acceleration when it reaches point B, where S = 51.5 m. (the max height of the hill is 16 m, and the function of the hill the car is on is y = 16 -(1/625)x^2. A intersects the axis at the furthest point from the origin in the positive direction. S (the Car) is left of A between A and B.)
The position and velocities given and the radius of curvature (rho) equation.
I've solved this problem, that is, the magnitude of an and at. However, an is in terms of x because I can't figure out how to get an x range. I know if I had a "let x = #" I would plug it into the y = 16 -(1/625)x^2 and crunch it to get a Vy, so I'm stuck. Thanks in advance...
Cancel...I solved it...I needed to use intsqrt1+dy/dx to find x, then just plug and chug...
