Finding time when you have initial velocity and position
To find the total time for the rocket's flight after leaving the incline, one must consider its initial velocity and the effects of gravity. The rocket accelerates along a 200.0-m incline at 1.36 m/s², reaching a velocity of 23.323 m/s at the end of the incline, with a horizontal component of 19.105 m/s. After the engines turn off, the rocket behaves like a projectile, and gravity acts downwards, not sideways. The equation for horizontal distance combines the initial horizontal position, the horizontal velocity, and the effect of gravity over time. The key challenge is determining the total time of flight to complete the calculations for maximum height and horizontal range.
oliampian
***Sorry I meant to say finding time when you have initial velocity and position***
1. Homework Statement
A test rocket is launched by accelerating it along a 200.0-m incline at 1.36 m/s2 starting from rest at point A (the figure (Figure 1) .) The incline rises at 35.0 ∘ above the horizontal, and at the instant the rocket leaves it, its engines turn off and it is subject only to gravity (air resistance can be ignored).
Find the maximum height above the ground that the rocket reaches.
Find the greatest horizontal range of the rocket beyond point A.
Known:
Vo = 0 (because starting from rest)
aon incline = 1.36 m/s2
aoff incline = -9.8 m/s2
ramp distance = 200m
θ = 35°
x = xo + Vot + (0.5)at2
V = Vo + at
V2 = Vo2 + 2aΔx
I already found the first part, which turned out to be 124m when rounded to three sig figs.
I found through calculations that Vat end of incline = 23.323m/s:
using the V2 = Vo2 + 2aΔx
Vat end of incline = √(2(1.36m/s2)(200m))
Vat end of incline(x-component) = 23.323m/s(sin(35)) = 19.1050m/s
Distance in x-component = Dx = 200m(cos35) = 163.8304
So to find the total horizontal distance so far I have the equation:
x = 163.8304 + 19.105t - 0.5(9.8)t2
What I'm stuck on is trying to find the total time so I can plug that into the equation.
Known:
θ = 35°
V = Vo + at
V2 = Vo2 + 2aΔx
Where does this equation come from? And when did gravity start acting sideways?
When the rocket leaves the ramp, the engines turn off, so the rocket just coasts until it lands.
When the rocket leaves the ramp, it acts like any other projectile. You have an initial velocity and an angle at which the rocket is traveling relative to the horizon.
