Finding time with force, mass and velocity
6 replies · 3K views
Ally385
Small rockets are used to make tiny adjustments in the speeds of satellites. One such rocket has a thrust of 35 N. If it is fired to change the velocity of a 71700 kg spacecraft by 66 cm/s, how long should it be fired?
p = mv
Impulse = FΔt
Well I think that you might have to find momentum and then plug that into another equation. I'm just not sure what equation that would be since the impulse = FΔt doesn't use momentum.
Look up the 'impulse-momentum' theorem.
Start here: The Impulse-Momentum Change Theorem
So that would make it:
F Δt = Δ p
So that makes that
Δt = Δp/ F
Δt = 4732200 - 0 / 35
Δt = 135205.7
But now how do I get rid of the delta?
F Δt = Δ p
Right.
So that makes that
Δt = Δp/ F
Δt = 135205.7
Careful with units. Convert the speed to standard units of m/s.
Δt is what you are solving for. (You don't need to get rid of the delta; Δt is the time that the thrust must be applied.)
So is it in cm/s now because that's what it says in the problem? And then do I have to change it to minutes because that's what it asks for next to the answer blank. (Sorry forgot to put that in.)
Yes. You need to convert that to m/s.
Exactly. The equation will give you the time in standard units of seconds. If you need the answer in minutes, you'll have to convert units.
