Finding uniqueness of PDE via. energy method
In summary: Your idea is basically good though, and needs only a little modification. Instead of c\int_{\Omega}^{}v^{2} = -\int_{\Omega }^{}|\triangledown v|^{2}we will instead have(c-\alpha)\int_{\Omega}^{}v^{2} \le -\int_{\Omega }^{}|\triangledown v|^{2}where the constant α depends on b and Ω, but not v. Then you choose c so that (c-α) is...small?
Weilin Meng
25
consider a solution such that:
[tex]-\triangle u + b\triangledown u + cu = f[/tex]
in domain Ω
and
[tex]\delta u/\delta n=g[/tex]
in domain δΩ
where b is a constant vector and c is a constant scalar. Show that if c is large enough compared to |b|, there is uniqueness
Energy Method to find uniqueness
Divergence theorem
Assume two solutions u1 and u2. and v = u1 - u2
by linearity: [tex]-div(\triangle v) + b\triangledown v + cv = 0[/tex] in Ω
and [tex]\delta v/\delta n=\triangledown v\cdot n=0[/tex] in δΩMultiply the PDE by v and integrate over Ω:
[tex]\int_{\Omega }^{} -div(\triangle v)v + b\triangledown vv + cv^{2} = 0=\int_{\partial \Omega }^{}\triangledown v\cdot nvd\sigma +\int_{\Omega }^{}|\triangledown v|^{2}+b\triangledown vv+cv^{2}[/tex]
(used divergence theorem to change the first integral on the right hand side.)
since [tex]\delta v/\delta n=\triangledown v\cdot n=0[/tex]
The integral becomes:
[tex]\int_{\Omega }^{}|\triangledown v|^{2}+b\triangledown vv+cv^{2} = 0[/tex]
if c is large enough, then it is the same as saying that b is very small. So we can consider b = 0 and therefore: [tex]b\triangledown vv = 0[/tex]
so we get :
[tex]c\int_{\Omega}^{}v^{2} = -\int_{\Omega }^{}|\triangledown v|^{2}[/tex]which is only possible if v=0
therefore u1-u2 = 0
and u1=u2, and we have uniquenessI'm not too sure about the last few steps. Do you think it's valid?
Looks all good except for the missing steps in this part:
if c is large enough, the is the same as saying that b is very small. So we can consider b = 0 and therefore: [tex]b\triangledown vv = 0[/tex]
so we get :
To rigorously go from the first equation to the second, you need that the integral over [itex]\Omega[/itex] of [itex]v b \cdot \nabla v[/itex] is not unboundedly larger than the integral of the function v2. (do you see why?) More specifically, we want
[tex]| \int_\Omega v b \cdot \nabla v | \le C \int_\Omega v^2 [/tex]
With some integration by parts you can get the left hand side of this to be equal to a constant times the integral of v2 over the boundary. So you need some way to relate the integral of v2 over the boundary to the integral of v2 over the inside - I would suggest using a trace theorem.
I don't see why. So it's not ok to just subtract cv^2 to the other side?
Consider if you had solutions u1, u2, u3, ... corresponding to some subtracted versions v1, v2, v3, ...
What would happen if [itex]|b \cdot \nabla v1| = 1|v1|[/itex], [itex]|b \cdot \nabla v2| = 2|v2|[/itex], [itex]|b \cdot \nabla v3| = 3|v3|[/itex], ...
Remember, you would like to have some condition that says "the solution is unique if |b| < const*c". That const could be very large and you don't even have to know what it is, but it can't be infinite.
Remember, you would like to have some condition that says "the solution is unique if |b| < const*c". That const could be very large, but it can't be infinite.
Hmm. I thought that with the question saying that "If c is large enough compared to b", that was saying that c was so much larger, that we can just ignore the b part of the equation, which is why I set b = 0.
But now I think I see that I am considering only one case, and I need a more general situation. That's where the inequality comes in?
Yeah, so c can be much much larger than b, but how much larger can't depend on which particular solution v you are considering.
[tex](c-\alpha)\int_{\Omega}^{}v^{2} \le -\int_{\Omega }^{}|\triangledown v|^{2}[/tex]
where the constant α depends on b and Ω, but not v. Then you choose c so that (c-α) is positive.
ok, I'm a little confused of how to go from: [tex]
to
since we're not exactly eliminating b anymore...I'm trying to work backworks and convert the inequality to the original integral, but I can't get a to be independent of v
Ok, supposing that
[tex]| \int_\Omega v b \cdot \nabla v | \le \alpha \int_\Omega v^2 [/tex]
could you see how to get there?
[tex]
I tried to do integration by parts on [tex]b\triangledown vv[/tex]
In hopes of trying to eliminate [tex]|\triangledown v|^{2}[/tex]
But no luck...you mentioned the trace theorem. Is that necessary? I am not familiar with it.
All of those little tricks - integration by parts, trace theorem, etc - are needed to show that
We will get to that.
But first, assuming that the above equation is true, can you get from
A: [tex]
\int_{\Omega }^{}|\triangledown v|^{2}+v b \cdot \triangledown v+cv^{2} = 0[/tex]
to
B: [tex](c-\alpha)\int_{\Omega}^{}v^{2} \le -\int_{\Omega }^{}|\triangledown v|^{2}[/tex]
Hint: if you are doing a lot of tricks, you're trying too hard! It's straightforward!
assuming that the above equation is true...I take equation A:
[tex]
I then move things around and take the absolute value:
[tex]|\int_{\Omega }^{}b \cdot \triangledown vv| = \int_{\Omega }^{}|\triangledown v|^{2}+cv^{2}[/tex]I plug it into the above equation and I get equation B!
So from equation B, if we set (c-a) to be positive, the inequality can only hold with v = 0?
Ok if we have that...how do we get the above equation?
Great!
So now we want to show that
Before we get started algebraically, give a few thoughts as to what this inequality means intuitively. For any solution v, the gradient of v can't be "too big" compared to the original v (when integrated). Just take a few seconds to think about this to build your intuition.
Ok, now let's get started. Look at the intequality. On the left side, there is a derivative (the gradient) of v, but on the right side there is only v's and no derivatives. To go from the left to the right, we have to get rid of the derivatives. How to do this? Integration by parts, of course!
Your mission, if you choose to accept it, is to take
[tex]\int_\Omega v b \cdot \nabla v[/tex]
and convert it into something else that doesn't have any derivatives in it. (hint: express [itex]b \cdot \nabla v = \sum_i b_i \frac{\partial}{\partial x_i} v_i[/itex] and integrate each term by parts). What happens?
Once you get rid of the derivatives we can go to the next step.
I'm not sure if I did this right, but this is what I got so far and it looks like a mess and i did this assuming we're in R^3:
[tex]\int v(b_1\partial v_1/\partial x_1+b_2\partial v_2/\partial x_2+b_3\partial v_3/\partial x_3)=(vv_1b_1-\int v_1\partial v/\partial x)+(vv_2b_2-\int v_2\partial v/\partial x)+(vv_3b_3-\int v_3\partial v/\partial x)[/tex]I want to say that that equals to:
[tex]bv^{2}-b\int v\triangledown v[/tex]
Ahh so that is integration by parts for Ω 1D. In many dimensions, it goes: (n normal vector with components ni)
[tex]\int_\Omega v \frac{\partial}{\partial x_i} u = \int_{\partial \Omega} u v n_i - \int_\Omega u \frac{\partial}{\partial x_i} v[/tex]
Give it another try with this one.
ok, so would the integration be this?
[tex]\int_{\partial \Omega }^{}v^{2}n_i-\int_{\Omega }^{}v\frac{\partial v}{\partial x_i}[/tex]
yeah sorry i was editing in the meantime 1 sec. I need to check my work to be careful about things here. The end result is that you get v^2 integrated over the boundary.
Ok well, I am going to come back to this tomorrow...it's already 3 am lol...I have another similar question with non-linear equations...but that won't take nearly as long.
good night!
Yeah ok you should get
[tex]\int_\Omega v \nabla v \cdot b = \int_{\partial \Omega} v^2 b \cdot n - \int_\Omega v \nabla v \cdot b[/tex]
But then look: the last term on the right is minus the term on the left, so you can bring it over to get
[tex]\int_\Omega v \nabla v \cdot b = \frac{1}{2}\int_{\partial \Omega} v^2 b \cdot n [/tex]
so
[tex]| \int_\Omega v \nabla v \cdot b | \le \frac{1}{2}|b|\int_{\partial \Omega} v^2 [/tex]
You should actually compute this in coordinates, since this sort of thing occurs all the time and it is useful to be comfortable with the manipulations. Also compute it if for no other reason than to check and make sure what I've written here is right... you can see I've made mistakes in the calculation a couple times already ... (-:
Tomorrow give some thought about how this relates to the inequality we are trying to prove.
Question, where did the n disappear to?
Ok so right now we have the left side of the inequality...somehow we need to convert the right to domain omega, and get constant a which depends on b. Does b/2 = a?
The n got bounded out, remember |b.n| <= |b| since n has length 1
[tex]|\frac{1}{2}\int_{\partial \Omega} v^2 b \cdot n | \le \frac{1}{2}\int_{\partial \Omega} |v^2 b \cdot n| = \frac{1}{2}\int_{\partial \Omega} v^2 |b \cdot n| [/tex]
b/2 = a is a good guess, but not quite. We will pick up another constant from going to the boundary to the whole domain.
I'll take a look, but I'll have to continue this in about 2 days...got an orgo midterm to study for.
What is the "energy method" used for in PDE analysis?
The energy method is a mathematical technique used to prove the uniqueness of solutions to partial differential equations (PDEs). It involves using the concept of energy, which is a measure of the stability or equilibrium of a system, to show that a particular solution is the only one that satisfies certain boundary conditions.
Can the energy method be applied to all types of PDEs?
Yes, the energy method is a general technique that can be applied to a wide range of PDEs, including linear and nonlinear equations, as well as boundary value and initial value problems. However, the specific details of the method may vary depending on the type of PDE being studied.
How does the energy method differ from other methods used to prove uniqueness of PDE solutions?
The energy method is based on the principle of energy conservation and uses the concept of energy to show that a particular solution is the only one that satisfies certain boundary conditions. This is different from other methods, such as the maximum principle or the method of characteristics, which rely on different principles and techniques to prove uniqueness.
Is the energy method a reliable way to prove uniqueness of PDE solutions?
Yes, the energy method is a well-established and widely used technique in PDE analysis. It has been successfully applied to many different types of PDEs and has been proven to be a reliable method for proving uniqueness of solutions. However, like any mathematical method, it requires careful application and may not always be applicable in every situation.
Are there any limitations or drawbacks to using the energy method?
While the energy method is a powerful tool for proving uniqueness of PDE solutions, it does have some limitations. For example, it may not be applicable to PDEs with irregular or discontinuous coefficients, or to problems with complicated boundary conditions. Additionally, the method may require advanced mathematical techniques and can be quite challenging to apply in certain cases.
