What is the Fine Structure Constant?
The fine structure constant is a dimensionless number represented by the formula α = e²/(2hcε₀), and its significance remains somewhat mysterious. There is ongoing debate about whether this constant has changed since the beginning of the universe. Users suggested Wikipedia and Google as starting points for research, but some found the information insufficient. Additional resources, such as a recent article from Cambridge University, were recommended for further exploration. The discussion highlights the complexity and intrigue surrounding the fine structure constant.
Raparicio
Does anybody knows a good reference or book that explains the "fine structure constant"?
Raparicio said:
I've tried both, but there's no enought information.
The fine structure constant is just a dimensionless number:
\alpha = \frac{e^2}{2hc\epsilon_0}
Its significance is somewhat of a mystery. You won't find a very good answer to that question.
The current debate seems to be whether the fine structure constant has changed since the beginning of the universe. see: this recent article.
http://www.ast.cam.ac.uk/%7Emim/res.html should also help.
AM
I don't knew that was a mistery... but now understand that my question is not only mine. Thanks for all.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
