First Law of Thermodynamics - easy q's
The discussion addresses two homework problems related to the First Law of Thermodynamics. In the first problem, the user struggles with calculating the internal energy of a gas after adiabatic compression, mistakenly not converting units properly and failing to use consistent pressure units. The second problem involves calculating work done by a gas expanding under a specific pressure-volume relationship, where the user incorrectly applies the formula without considering the need for calculus due to the changing pressure. Participants emphasize the importance of unit conversion and consistency in calculations. Overall, the thread highlights common pitfalls in thermodynamic problem-solving and the necessity of understanding underlying principles.
dtavob
The internal energy of a gas is 600 J. The gas is compressed adiabatically, and its volume decreases by 400 cm3. If the pressure applied on the gas during compression is 4 atm, what is the internal energy of the gas after the adiabatic compression?
Change Q = Change U + Change W
Since it's adiabatic then change in Q = 0...
So it should be change U = - change W...
(Ufinal - Uinitial) = - (4*4) ----I also tried changing atm to pascals, but the answer is still wrong.
What am i doing wrong? Anyone please.
A gas has an initial volume of 7.05 m3. It is expanded to six times its original volume through a process for which P = αV3, with α = 4.00 N/m11. How much work is done by the expanding gas?
W = P*delta V
So P = 4*7.05^3 = 28.2
delta V = (Vfinal - Vinitial) = (7.05*6) - 7.05 = 35.25 m3
so W = 994.05 J. The correct answer is 3.20e6 J, but I don't understand what I'm doing wrong. Anyone please?
hello,
in the first problem you are not converting cm^3 to m^3 correctly. and you do need to use Pa for pressure. you must be consistent with your units throughout any formula.
if i understand the second problem correctly, the volume and pressure are changing at the same time and are related by P = a*V^3 (i assume the 3 is an exponent). for this, one needs calculus.
W = \int_{V_1}^{V_2}{P}dV
Woah. Thank you so much. I guess I was just too hungry to think right =/.
cheers.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
