Creating a Near Perfect Flat Surface: Difficult but Possible
  • Thread starter Thread starter sid_galt
    Flat Surface
Achieving a near-perfect flat surface with roughness between 1-10 nm is challenging but possible, particularly in specialized applications like carbon face seals. The best flatness typically observed is around .000035", equivalent to three helium light bands, but achieving nanometer-level flatness introduces significant macroscopic challenges. Polishing to such precision requires a careful, multi-stage process, often done by hand, and is highly material-specific, with Gallium Arsenide being a common focus for research purposes. The need for such low tolerances is driven by the measurement of quantum transport phenomena in GaAs structures, which are critical for fundamental research. Overall, while difficult, the pursuit of ultra-flat surfaces is feasible with the right techniques and investment.
sid_galt
Is it possible to get a near perfect flat surface with the roughness no more than 1-10 nm at any point?
If it is, then how difficult is it?
The surface of carbon face seals are extremely flat with incredibly smooth surface finishes. The flatness callouts I am used to seeing are .000035" or about three helium light bands. That is about the best I have ever seen. I think you'd be running into macroscopic troubles when talking about surfaces in terms of nanometers.
Here is a reference for you on the topic in regards to sealing surfaces and pumps:
http://www.mcnallyinstitute.com/Charts/flatness_readings.html
For those interested, The Mcnally Institute website has some fantastic information regarding pumps and seals. It is a very valuable resource!
We routinely make samples that have a flatness and parallelism of less than 100nm over an area of about 10 sq. mm. The polishing process is both tricky and painful (in addition to being material specific), and getting a better flatness would require a substantially greater monetary investment.
What material are you working with, and what is the size of the active area that you want flat ? And what's your budget ?
I am not working on any material. I was just curious.
What componds do you polish with? Is this by hand? What is the purpose of the flatness/finish tolerance being so darned low (applications)?
The polishing is done in several stages, mostly by hand, with the assistance of a polishing jig. The polishing compound is very specific to the material that we are polishing - Gallium Arsenide. Why do we need this low a tolerance ? Because we measure quantum transport phenomena in GaAs quantum well structures where the well spacing in just few tens of nanometers. This is fundamental research and has no applications as of now.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
