Flow on the surface of a cylinder
Matt atkinson
An infinite cylinder is moving at constant velocity \vec{U} in a stationary background flow. On the surface of the sphere no fluid penetrates, so that \vec{U} \cdot \vec{n} = \vec{u} \cdot \vec{n}. Where \vec{n} is the vector normal to the surface of the cylinder. At the instant the axis of the cylinder coincides with the origin, the velocity potential in cylindrical polar coordinates is given by;
\phi=-\frac{U a^2 cos(\theta)}{r}
where a is the radius of the cylinder.
i) find the velocity field \vec{u}
ii) prove the relavent boundry condition for the background flow.
iii) Find \vec{U}
i) basical it is grad \phi I got \vec{u} =\frac{U a^2 cos(\theta)}{r^2} \vec{r}+\frac{U a^2 sin(\theta)}{r^2} \vec{\theta}
ii) not sure what boundry i tried solving U dot n = u dot n
with n as r_hat, but didnt get anywhere.
for ii) I proved that \nabla \times \vec{u} = 0 which shows its irrotational but I am not positive if that's the correct thing to do
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
