Flow Rate of a Deflation Balloon
The discussion revolves around modeling the flow rate of a drug delivery infusion pump that utilizes a deflating balloon filled with liquid. Participants explore how to derive the flow rate as a function of time, considering factors such as temperature and drug viscosity, while also discussing the implications of the balloon's elastic properties on flow dynamics.
  • Some participants propose using the Poiseuille-Hagen equation to model the flow rate, while others suggest that it may not apply due to the presence of a resistive element (a 'frit') in the outlet.
  • There is a suggestion to consider Darcy's law or a modified Poiseuille's law that includes a resistive term, known as the Brinkmann equation.
  • Participants note that the flow rate is not constant and appears to decrease as the balloon deflates, influenced by the diminishing elastic energy of the balloon.
  • Some participants express the need for simplifications in the model, such as assuming a perfect spherical shape for the balloon or constant temperature, to facilitate calculations.
  • There is a discussion on the geometry of the balloon during deflation, with options presented for modeling either a constant diameter or a spherical shape as volume decreases.
  • One participant emphasizes the complexity of modeling due to the elastic nature of the balloon and expresses uncertainty about creating a realistic model.
Participants generally agree that the flow rate is not constant and decreases over time, but there is no consensus on the best modeling approach or the applicability of specific equations. Multiple competing views on the modeling techniques remain unresolved.
Limitations include the need for additional data on the balloon's geometry and outlet characteristics, as well as assumptions regarding the fluid properties and environmental conditions that may affect the flow rate.
wuyx724
A drug delivery infusion pump is made out of thick synthetic rubber and has a very small outlet. The balloon pump is filled with 500mL liquid drug and is now inflated into a ball shape. The drug will exit from the very small outlet at a nearly (but not always) constant flow rate of 5mL/hr (takes 100hr to deplete).
How can I derive the flow rate as a function of time?
I'd also like to know how the temperature and drug viscosity affect the flow rate.
Someone suggested me to use Poiseuille-Hagen equation, but I need to know more details, especially how I can relate the flow rate to time and establish a model.
Your insight will be highly appreciated!
Let me know if I'm right: You have a liquid-filled balloon (spherical i guess) which has a little outlet through which liquid is verted outwards. So despite you give a value of a certain flow rate you'd like to know how it evolves with time?
Thanks for clarifying :)
That's exactly what I meant!
The "constant flow rate" is only indicative (by product manufacturer). The actual flow rate seems decreasing as balloon deflating (from experimental data).
Looking forward to your solution!
Oh! thanks for your trust :) you know its funny because I did something really similar to this yesterday helping another post.
But I'm afraid I need more data because this is a very complex situation and if we want to obtain a practical solution (so that we can even calculate our own time of deplete, for example) we´ll have to do some simplifications in order to modelize the balloon.
May you describe it to me a little more? thanks a lot
can you tell me where that post (the similar question you answered yesterday) is located?
sure we can simplify the model to start with, such as a perfect sphrical balloon shape, or even cylinder shape if that makes it easier, water as fluid, constant temperature, etc. I don't know what other information you need.
Yes sure, the post is "Need formula/help with mass air flow" at Physics > Classical Physics, it was similar but not the same because there we dealed with a fixed-volume air tank. However some eqs. may help.
The information I need is to modelize the balloon. Whether it decreases in volume as a sphere (or nearly does) or just wrinkle when water is released, or the description of the outlet in size, shape... are data that will allow us to make a good "practical" model of the pump.
Thanks a lot.
We can assume either
(1) the balloon remains as a sphere when the volume decreases, or
(2) the balloon keeps one diameter (along the axis of outlet) constant, while the radial dimension decreases.
whichever is easier.
The balloon is connected to a tubing, which has a very small outlet. The whole setup is more like the IV infusion bag, but instead of using a medication bag and the gravitation, we have an elastomeric balloon here.
Well, I see. The fact is that this is quite complicated because of the elastic nature of the balloon. Picking one of the options, it'd be far easier (1) rather than changing the very geometry of the balloon each second. I´m afraid I can't make a practical model of this if I consider it "realisticly" elastic.
If i come up with an answer for anythig different I tell you.
I'm sorry, :(
It's not just a small hole (at least the devices I have seen)- there is a 'frit' inside that produces a constant resistance. The elastic energy of the balloon produces the driving force, pushing fluid through the porous frit.
The Hagen-Poiseuille equation will not readily apply, due to the presence of the resistive element. A better approach would be Darcy's law (Or Poiseuille's law with a resistive term, sometimes called the Brinkmann equation).
That's because the elastic energy of the balloon slowly dissipates as the balloon deflates- think of it as the driving force decreases over time.
17K
10K
