Fluid force from a fluid flow vs. from a fluid jet
The discussion revolves around the differences in calculating fluid force from a fluid flow versus a fluid jet impacting a surface. Participants explore the theoretical underpinnings, including kinetic energy and momentum transfer, and how these concepts apply to different scenarios in fluid dynamics.
  • Some participants note that the force from fluid flow is derived from kinetic energy as ρAv²/2, while the force from a fluid jet is derived from momentum as ρAv², leading to confusion about the absence of the 1/2 factor in the latter case.
  • Others propose that reflecting a stream of particles results in double the momentum transfer compared to absorption, suggesting a different force calculation for each scenario.
  • A participant mentions that dynamic pressure and momentum change are related but differ by the factor of 1/2, indicating a need for clarity in the calculations.
  • Concerns are raised about the reliability of sources like Engineering Toolbox, with one participant asserting that the force on a submerged plate is generally proportional to dynamic pressure, involving a drag coefficient.
  • Some participants discuss the implications of drag coefficients, noting that values greater than 2 could lead to forces larger than those predicted by momentum equations, which adds to the confusion.
  • One participant explains that the force calculation depends on whether mass or velocity is constant, leading to different interpretations of the problem based on the scenario described.
  • Another participant emphasizes the complexity of flow fields, arguing that the differences in momentum transfer between an impinging jet and an immersed plate stem from the surrounding fluid dynamics.
Participants express differing views on the calculations and interpretations of fluid force in various scenarios. There is no consensus on the correct approach or the reasons for the discrepancies in results.
Participants highlight limitations in the sources referenced, including assumptions about flow conditions and the complexity of drag coefficients, which may not be fully addressed in the provided links.
Ola Sweden
In fluid flow (such as wind), the force exerted on a perpendicular surface is derived from kinetic energy and is ρAv^2/2. But in problems involving a jet of fluid that strikes a plate, the force is derived from momentum and is explained to be ρAv^2, lacking the 1/2 factor. Can someone please explain this?
:welcome:
Can you be more specific about the scenarios you are analysing?
My first thought is that if an object reflects a stream of particles, then the force is twice that for the case where the particles are absorbed. I.e. there is twice the momentum transfer in reflection compared to absorption.
PeroK said:
:welcome:
These 2 links explain the different solutions. Dynamic pressure vs momentum change. As I see it, it is the same problem. A flow of a fluid causes a force on a surface perpendicular to the flow, as it stops the flow. But the solutions differ by this factor 1/2.
https://www.engineeringtoolbox.com/wind-load-d_1775.html
https://link.springer.com/chapter/10.1007/978-1-349-00870-4_16
The first link is far less explicit about the calculations, and doesn't explain why only half of the momentum transfer applies.
The second explicity assumes the momentum of the water jet is lost. That looks correct to me.
I guess it is considered pretty basic physics and they don´t go into it that deep. This wikipedia link offers some insight:
https://en.wikipedia.org/wiki/Drag_equation
I was wondering if anyone has had the same question as I do and found out why the two approaches yields different results, it is very disturbing to me :(
If a large rectangular surface has a drag coefficient of ##2##, then the equations agree.
https://en.wikipedia.org/wiki/Drag_coefficient
Yes, I have also had the thought that the answer to this is related to that. But- sometimes the drag coefficient is even >2 which means the force would be even larger than the momentum equation would yield... confusing.
Greater than ##2## might be an curved surface (curved the wrong way aerodynamically), where the wind cannot escape laterally and is forced back. The maximum coefficient would be ##4##, perhaps, corresponding to total reflection of the incoming fluid.
I would say it depends on the problem. Do we assume that the mass or the velocity is constant?
If a mass of fluid is moving from point A to point B and its velocity changes then the force is ##\frac{d(mv)}{dt} = m\frac{dv}{dt}## because ##m## is constant where ##m = \rho V##. The kinetic energy is thus ##\frac{1}{2}\rho V v^2##, which agrees with the principle behind the Bernoulli equation, i.e. conservation of energy. And the dynamic pressure ##p_k## is defined as the kinetic energy per volume, thus ##p_k = \frac{1}{2}\rho v^2##.
With a jet of water, the problem is seen differently. The jet comes out of some pipe with a known cross-sectional area ##A## and outlet pressure ##p## and velocity ##v##. Here the velocity doesn't change, therefore the force is ##\frac{d(mv)}{dt} = v\frac{dm}{dt}## because ##v## is constant and it is a small mass of water that is constantly added, which is equal to ##dm = \rho dV = \rho A dx##, thus ##F = v \frac{\rho A dx}{dt} = \rho A v^2##. And then ##p = \frac{F}{A} = \rho v^2##.
Maybe others have a better explanation.
For one, the force on a submerged plate is not what your links say it is, i.e.
[tex]|F|\neq\frac{1}{2}A\rho v^2.[/tex]
Engineering Toolbox is sort of renowned for wrong answers, in my experience. In reality, the force is generally proportional to dynamic pressure,
[tex]|F|\propto\frac{1}{2}A\rho v^2,[/tex]
by way of the drag coefficient, ##C_D##:
[tex]|F|=\frac{1}{2}C_D A\rho v^2.[/tex]
The physics that determine the value of ##C_D## are, to put it mildly, very complex.
The most intuitive answer for why the impinging jet and immersed plate problems are different is because the flow fields are different. The immersed plate has fluid all around it, which affects the way momentum is transferred into the plate. It also has a much greater contribution to the final answer from the wake behind it while the jet problem has nearly zero contribution from the wake.
How do you mean the velocity doesn´t change? The velocity goes from v to zero in the direction of the flow does it not?
Ok this seems interesting.. First, Engineering Toolbox is not the only source for that equation, it is generally accepted when it comes to wind force, like in the Eurocodes for example. I see what you mean with the complexity though, but that sort of comes in with the shape coefficients and not the generic equation. There seems to be something fundamental I am missing here.
I´ve always thought about it as simply a mass m with a velocity v and thus a kinetic energy E has to be braked to a halt in a time t which correlates to a distance d. And so the braking force must be easily obtained from knowing the kinetic energy. But I see now that it might be a bit more complicated when it comes to fluids...
If you measure the velocity of the water at the outlet of the pipe, it will be constant even though the source of the water may be a very large tank where the velocity is assumed to be zero. What changes is that new water is always added to the jet. Once the jet hits the plate, I just assume it is the same thing in reverse. It's a question of choosing the appropriate control volume.
Again, maybe others may explain this better.
In the link there is a note:
https://www.engineeringtoolbox.com/wind-load-d_1775.html said:
Note - in practice wind force acting on a object creates more complex forces due to drag and other effects.
Based on this document, no forces are estimated without a coefficient included. (Although there are 3 special cases where ##C_sC_d = 1##)
The static (thermodynamic) pressure in a moving fluid is ##p##. This ##p## is the pressure "felt" by an object immersed in a fluid. The dynamic pressure in that fluid, which is essentially a measure of kinetic energy per unit volume, is ##1/2\rho v^2##. If you combine the two, you get what we call total pressure or stagnation pressure,
[tex]p_0 = p + \frac{1}{2}\rho v^2.[/tex]
Unless there is a dissipative process occurring, total pressure is constant in the flow, so when a fluid stagnates (comes to rest) against an object immersed in it like your plate, ##v\to0## and you end up with
[tex]p = p_0.[/tex]
From above, you know that ##p_0>1/2\rho v^2##, so by extension we know that the force on that side of the plate, ##F=p_0 A##, has to be higher than that provided by the dynamic pressure alone.
Now, the net force on the plate is
[tex]F_{\mathrm{net}} = F_{\mathrm{front}} - F_{\mathrm{back}} = \left(p + \frac{1}{2}\rho v^2\right)A - p_{\mathrm{back}} A.[/tex]
So, the only way that the net force is equal to ##1/2 A\rho v^2## is if ##p_{\mathrm{back}} = p##. This is not generally true, however, because a wake will form behind the plate as the fluid moves over it, and that wake will generally produce static pressures that are lower than ##p##, we know that the net force will also generally be greater than that provided by static pressure alone.
Of course, the front of the plate is not identically at ##p_0## across the entire acreage, either. The flow is only truly zero velocity (without the action of a dissipative process) at the stagnation point, so this is an imperfect analysis. But it does serve to illustrate that simply using the dynamic pressure doesn't work.
You are totally correct.
But it is not at all that interesting. Drag is actually misleading the answer to your question.
Engineering toolbox is accepted for the force of the wind on a surface.
Drag force is that for an object subjected to a moving fluid, and can contain skin effects due to viscous effects, as well as the force from the form of the object due to the cross section.
None of that applies to your question about the force on a surface.
You asked about the force on a surface, and why force obtained from Bernuoilli, and stagnation pressure, or from the impulse-momentum equation give different answers by 1/2.
Should you design your windows of your house by which equation so that they do not blow in.
No, as boneh3ad said, Engineering Toolbox is wrong here (and they are frequently oversimplified). The correct answer will always involve a coefficient Cd, and will vary significantly depending on the geometry. In some cases, Cd will be close to 1, in which case it will be equal to the engineering toolbox equation, but that is not generally true.
As for the jet, boneh3ad already explained the differences quite well there, so I'll just refer to his post above.
  • · Replies 28 ·
  • · Replies 35 ·
  • · Replies 48 ·
  • · Replies 18 ·
  • · Replies 20 ·
