(Fluids) Difference in stress or pressure between setups?
10 replies · 3K views · last reply
MrSmit
Hello,
I'm a PhD student in medical biology and am doing experiments with bloodvessels. I've modified an existing technique and getting unexpected results (ofcourse..). I think it is due to a pressure difference but my knowledge of physics is inadequate to be sure. Ill give a short explanation of the techniques and then at the end put a hopefully not too difficult question.
The technique I'm using is pressure myography; we cut a small section of a bloodvessel from tissue and attach each end to a glass cannula in a vessel chamber (see image one). The chamber contains fluid (salt solution) and is closed during the experiment. The chamber is not airtight, there are two open ends at the sides but the water from the chamber does not leak from them. Then, the pressure inside the vessel is raised to ~80 mmHg by closing one of the cannulas and attaching a water column to the the other (which is open at the end).
This is the standard situation (situation 1).
In my modified setup, the fluid inside the chamber is continuously refreshed. Approximately 35cm above the chamber is a fluid reservoir (due to technical reasons). The fluid is then pumped into the chamber by a rolling pump at 15ml/min. The 'excess' volume goes back into the reservoir through a tubing. This is situation two.
My feeling tells me that there is increased pressure, or stress, on the bloodvessel in the second situation. Others however say that the pressure difference between the inside and the outside of the vessel probably becomes smaller and therefore the stress decreases.. I'm definitely in need of someone more experienced in this matter..
My questions are:
- Is there increased pressure in the chamber?
- Is there a possibility that the pressure inside the vessel changes?
- Is there a possibility that the stress on the vessel changes?
Thanks in advance!
Image 1
Microscope view of a small blood vessel segment mounted between two glass cannulas, with fine suture threads tied to each end, against a blue background with a graduated scale.
Image 2
Two schematic diagrams: Situation 1 shows a chamber with a red vessel at 80 mmHg and volume 2ml; Situation 2 shows a looped tube from a reservoir 35 cm high, pumped at 15 ml/min into a chamber with a 2mm vessel.
I can help you figure this out for yourself. First, here is an intermediate (3rd) situation for you to consider: Suppose that you were somehow able to get all the air out of the tubing, but the pump was not running, so no flow was occurring. So you have a hydrostatic equilibrium situation. Do you remember from freshman physics how to calculate the pressure at the bottom of a 35 cm column of water open at the top to the atmosphere?
While you are mulling this over, please tell me whether the pump is situated before or after the chamber. Also, is that 2mm equal to the inside diameter or the outside diameter of the tubing? Also, when the blood vessel is inflated to 80 mm Hg, do you have a rough idea what the inside diameter and the outside diameter of the blood vessel is?
Chet
Hello Chet,
Thank you for this approach. So, the hydrostatic pressure is density of the volume * gravity * height plus atmospheric pressure. So in my case that would be 1012 kg/m3 * 9.81m/s2 * 0.35m + 101325 Pa = 10480 Pa. In mmHg that would be a pressure of 786 mmHg.
As an answer to your questions;
- The pump is placed before the chamber
- The diameters are internal diameters
- A pressurized vessel has an inside diameter of approximately 130 μm and an outside diameter of 150 μm
OK. So, if we work with gauge pressures,
Situation 1:
Gauge pressure inside blood vessel = 80 mm Hg
Gauge pressure outside blood vessel = 0 mm Hg
Pressure difference = 80 mm Hg
Situation 3:
Gauge pressure outside blood vessel = 26 mm Hg
Pressure difference = 54 mm Hg
Because of the pressure difference between inside and outside the blood vessel, there will be a hoop tensile stress within the wall of the blood vessel. The hoop stress is given by:
$$σ=\frac{(d_o+d_i)}{(d_o-d_i)}\frac{Δp}{2}$$
Please calculate the hoop tensile stress within the wall of the blood vessel in the two situations.
In the case where water is being pumped (situation 2), the pressure in the chamber is going to be higher than in the static case (situation 3) because of the placement of the pump. So the tensile stress in the blood vessel wall will be still lower. If the pump were situated after the chamber, the pressure in the chamber would be less. We can calculate the additional pressure effect of the pumping to see how it compares with the hydrostatic pressure effect. To do that, we need to know the length of the tubing from the chamber back to the reservoir.
Chet
MrSmit said:
Hello Chet,
The calculated pressure is actually 104800 Pa.
Situation 1:
Situation 3:
Chet
Ok, so those tensions would be
$$σ1=\frac{(150+130)}{(150-130)}\frac{80}{2}$$
$$σ3=\frac{(150+130)}{(150-130)}\frac{54}{2}$$
Situation 1 = 560 mmHg
Situation 3 = 364 mmHg
The length of the tubing is 50 cm.
So, the stress on the vessel wall indeed becomes lower? Thats so counterintuitive (at least to me!)
I did some calculations on the fluid mechanics, and it doesn't seem like the fluid flow is going to contribute significantly to the pressure in the chamber. So the applicable comparison is between situation 1 and situation 3.
Chet
$$σ1=\frac{(150+130)}{(150-130)}\frac{80}{2}$$ = 560
$$σ2=\frac{(150+130)}{(150-130)}\frac{54}{2}$$ = 364
Yes. And those pressures are in mm Hg. It shouldn't be counter intuitive. Think of blowing up a balloon. The rubber membrane is under tension. If you decrease the pressure inside the balloon or increase the pressure outside the balloon, the stress in the rubber will be less. If you increase the pressure outside enough, you can collapse the balloon.
Chet
Yes, but isn't it important that gas is compressable and water practically isn't? My feeling tells me that if the internal pressure stays the same and an external pressure is present, the wall is 'squished' between pressures.
Thank you so much for your patience, I hope I don't come across as stuborn.
The rubber doesn't know whether there's air or water inside.
That's only in the radial direction, and it's a much smaller stress than in the hoop direction. So, yes the average radial compressive stress rises a little. But the hoop tensile stress drops substantially.
Chet
Alright. Thank you for the explanation Chet. This information makes my interpretation a little bit more difficult, but you can't argue with nature I guess haha!
