(Fluids) Material and local velocity and acceleration fields.
Lavabug
The streamlines of a fluid are as follows:
x = (x0) + 3(y0)t^2
y = (y0)/(1 + 2t)
z = (z0) + 5(x0)t
Find the velocity and acceleration fields in the Eulerian description (local).
Total/material acceleration: Dv/Dt = dv/dt + v.grad(v)
I am given the trajectories of the fluid in Lagrangian form, meaning a function of the initial positions and time. If I set t=0 I get x=x0, y=y0, z=z0 as the initial positions. I then solve for the initial positions as a function of x,y,z and t.
Next I take the time derivative of streamlines I am given to get the velocity field in Lagrangian(material) form, after which I substitute x0, y0, z0, which gives me the velocity field in local (Eulerian) form.
How do I calculate the acceleration? I can take the time derivative of the material velocity (2nd time derivative of the streamlines given) and then substitute x0,y0,z0. I can also use the formula I suggested, using it on the velocity field in local form (no initial positions in it).
My prof insists that doing it either way is equivalent but I've gone through the math several times and it simply isn't. Can someone please clarify these concepts/definitions for me once and for all?
Can you show the two procedures you are describing?
Here it is: http://img862.imageshack.us/img862/592/p1000992.jpg
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
